Question about Motorola Mobility SLVR L7 Cellular Phone
BATTERY CANNOT BE CHARGED
THE PHONE USB PORT SEEM NOT TO ACCEPT IT 'S CABLE CAUSE IT DON'T RESPONSE ON CHARGING MODE
  • 85 Answers
Go to google and search for charging drivers for it. I did it with a different phone and I found one immediately and it worked just fine.
Posted on Apr 18, 2008
Why is my iphone not charging?
This means it's not getting a charge. I've just experienced this problem myself. I followed instructions online regarding cleaning lint from the charging port of the phone. Still no charge. I bought a charging cable that came with a car charger made by Belkin, this worked in the car, also allowed me to charge the phone from the pc, but wouldn't charge from the original plug. So I purchased an original Apple branded lightning cable today and it works. At last. So it turns out that my cable was faulty and another branded cable would not work with the Apple plug. So you need to try a known working Apple cable and plug and failing that clean out the port on the phone as lint is a common problem.
Jan 02, 2015 | Apple iPhone 5S
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
I believe that my charging port on phone is coming loose. Is there anywhere that I can fix this? I really don't want to spend a ton of money either.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 30, 2012 | HTC Vivid
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
I have n97 but there is problem that when i connect the charger the led is on & battery bar showed no response nor charged with usb cable or usb charger .what should i do because in my city no one can...
It looks like the battery in the phone is not accepting the charge. This can be happening if the battery has gone bad. Please contact Nokia people for further assistance.
Please feel free to contact us for further information.
Jan 05, 2011 | Cell Phones
I plugged my iphone to the computer but it wont charge or sync
Try turning it off and then back on, if turning it on and off doesn't work, restoring it might work. Also try to remove the SIM card and put it back into the phone. I recommend simply exchanging the phone at the Apple store if it is still under warranty. Click on the links below to see other soultions for the charge and sync iphone problem
http://discussions.apple.com/thread.jspa?threadID=1392386
http://support.apple.com/kb/HT1737 (For PC users)
http://support.apple.com/kb/TS1410 (For Mac Computers)
Jan 06, 2010 | Cell Phones
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
How to charge my battery through the USB Data Cable
Well it does, I don't know what had happen to your cable but mine works...it automatically charges my phone every time I connects the cable to my PC.
There might be something wrong with your cable's charging capability or with your phones charging port.
Try to look for some switches if there is. But I think the problem is your Data cable's capability to charge.
Oct 03, 2008 | Samsung SGH-E370 Cellular Phone
Motorola W370 will not charge
Motorola provides a USB driver for just charging the W370. I installed it using the installation instructions from the Motorola website, but it just wouldn't work. The USB driver would install but would not activate (error Type 10). The W370 said that it could not charge. I recommend not bothering with this device driver, at least not with Windows XP.
However, I did figure out how to get the W370 charging from a USB port by trial and error. It's a pretty simple process.
1. Before plugging in the USB cable, turn on the W370 and wait for it to fully boot.
2. Connect the phone to the USB port of the computer.
3. When the phone asks "Connect phone as storage Device?", press the phone's left soft key, choosing "YES".
4. The phone will say "Please Wait...... Connecting Phone as Storage Device"
5. Eventually, the phone will display a white screen with the message, "In storage mode, no regular phone activities can be done."
6. Flip the phone closed. The yellow battery indicator will be lit. The phone is charging.
You'll note that the computer will see the W370 as a storage device with around 512 Megabytes of free memory, with empty "picture" and "sound" directories. The W370 appears to be a generic mass storage device to the computer. No special device driver is needed to charge the W370!
Mar 02, 2008 | Cell Phones
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
