Porosity, damage, misalignment
Channel Plate and Gasket, and Valve Body, Gaskets, and Channel Plate
Porosity, fluid leak across the channels, misalignment, damage, or fluid restriction
Low and Reverse Band and Servo
No apply or slipping
Servo Piston (69)
Broken or binding
Servo Piston Seals (71, 72)
Leaking
Servo Pin (67) and Springs (66, 68)
Binding
Servo Cover (73)
Broken, loose, or leaking
Low and Reverse Band (111)
Broken, worn, or out of position
Anchor Pin (64)
Broken
Fluid Feed Tubes (83)
Broken, bent, or plugged
Missing or leaking seal rings
Transmission Case (1)
Porosity, fluid leak, or restriction
Shift Linkage
Disconnected or misaligned
Manual Valve (800) and Link (802)
#1 Checkball
Missing, no low band fluid
Fluid Level
Low
Fluid Pressure
Low
Refer to High or Low Line Pressure .
suggest you take to an ASE certified transmission repair facility !
