Question about Vacuums
Red "bag is full" indicator shows even though new bag has been put in and vacuum cleaner wont pick up. Also floor adjustment does not adjust. This is for a powerforce model 3522 series
  • Nascarmom Apr 21, 2008
    thank you for your assistance, my son found and removed the clog and it is okay now. still need help in getting the floor adjustment level dial fixed where it will move up and down to adjust from high to lower. This is a great service you provide
    President:
  • 1,673 Answers
The red light tell you that it is sensing a full bag. But a clog in the hose or the inlet down by the brush roll will also do this.
Posted on Apr 20, 2008
  • Lauren Junge
    Lauren Junge Apr 21, 2008
    Here is a picture that you can look at, did a piece break off of the wheel carriage or the knob?
Bag shows full when it's empty. No clog in the hose, but when I start to vacuum, the bag-full indicates FULL, even though it's a new bag.
See if there are any sponge filters that might be clogged. They're usually between the bag and the air flow going to the motor.
Jan 29, 2017 | Vacuums
Bag showing as full when a new bag is in and all hoses unblocked
Hi There,
So when this light is displaying, it's says "Bag Full or Clog" on the indicator. If you have changed the bag, and it's still showing this light, it means that you either have a clog in the vacuum, or your filters are dirty, which is reducing the suction and making the machine think that your bag is full. If your machine is actually cutting off, this indicates that your machine is definitely clogged, or something is stuck inside which is causing the motor to not get air flow, and cauing the machine to over heat. When it shuts off like this, it's a protection system that prevents any damage from happening to the motor when it can't breathe and starts to overheat.
My guess is that there is probably a clog in the machine somewhere, or the filters are dirty. Here's what you may do to diagnosis the machine, and try to isolate the clog to find out where it is in the vacuum.
Step 1. Remove the hose and wand assembly from the vacuum cleaner completely. You may do this by pressing the two tabs on the end of the hose that plugs into the vacuum cleaner:
With the hose and the wand removed from the vacuum, it should look like this:
Step 2. Now turn the vacuum cleaner on and check to see if the red light comes on while the hose and the wand have been removed. If the light comes on, then this indicates that your filter is dirty (or the PCB electric board is bad if the filter is clean) and needs to be replaced.
Step 2. Re-attach the hose and wand back on the vacuum, but just the end of the hose that goes into the vacuum cleaner, leave the wand out of the vacuum cleaner so it looks like this:
Turn the machine on now as if you were using the attachment hose to clean corners or above the floor and see if the red light comes on here. Also listen to the noise the motor makes and see if the noise changes when you put the hose back on the vacuum cleaner. If the red light appears, or if the motor makes a higher pitched noise now, then this indicates that you have a clog in your hose or wand. You may verify this by remove the hose again from the vacuum, and also removing the wand from the hose by pressing the hose release button on the wand and pulling the hose out of the wand. Look down both of the parts and see if you can see thru both sides. If you're not able to see light through the hose, or the wand, this indicates this is where the clog is. You may take a metal clothes hanger, and try removing the clog this way.
Step 3. If the red light did not display with the wand not inserted into the vacuum, put the wand back into the vacuum cleaner as if you were vacuuming the floors:
Turn the machine on, and see if the red light comes on in this position. If the light does come on, then this indicates that you have a clog in the bottom of the vacuum cleaner. To check and see the clog in the bottom of the machine, I find it easiest to remove the upper bag housing from the vacuum cleaner completely so you're just looking at the bottom power nozzle of the vacuum cleaner. There's a button at the bottom of the machine that is either a grey, or yellow color depending on what color your vacuum is. Simply press this button in, and lift upwards on the handle or the bag housing at the same time:
Step 4. After the bag housing has been removed, turn the lower part of the vacuum upside down so the brushes are facing upwards. There's a little orange flap on the bottom of the machine that is actually a clog port. Almost every time there is a clog in a Sebo, this is where I typically find the clog. Open up this orange colored trap door, and look to see if you can see any obstruction or clog underneath of here:
Step 5. You may rotate the neck of the power nozzle part towards you so that you may look inside to see if you see any obstructions inside:
Step 5. You may also remove the brushes from the vacuum and look behind the brushes at the suction port, or the area where the suction goes through the vacuum to see if you see anything obstructing the suction here.
These are really the only places that the Sebo can get clogged. If you checked all of these areas, and the red light is still displaying, this means that your PC Board that controls this indicator has gone bad, and needs to be replaced. If this is the case, please just reply to this repair using the comment field, and I'll be more then happy to help you through the replacement of replacing the PCB Board.
I hope this answer was helpful to you, and you were able to find the clog and fix the problem. If you found my repair helpful, please be sure to rate the repair by clicking the 4 thumbs up icons in the top right hand corner, or by leaving feedback for me. This is really what keeps repair professionals continue to post free repair solutions rather then just the paid questions. It's really appreciated when you take the time and do this if the repair was helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Apr 27, 2010 | Sebo X4 Bagged Upright Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
Keeps showing the bag is full
are you getting suction.check the hose at the end and see if there is suction.is your brush roller turning.no suction will tell it that its full please leave feedback
Mar 20, 2009 | Bissell 3522 PowerForce Bagged Upright...
Vacuum 3522-5 won't pick up
I had that problem and it was indeed a clog in my hose. Even though I couldnt see it because it was way in there.
Nov 15, 2008 | Bissell 3522 PowerForce Bagged Upright...
Lost suction - Hoover Wind Tunnel S3630
You have a clog. The "bag full" indicator is nothing but a vacuum gauge, and impeding the airflow will cause a false indication of a full bag.
Clear your hoses and the air pathways behind the brushroll, and you will be back in business.
-R
Sep 27, 2008 | Vacuums
My electrolux canister vacuum roller does not spin even though it has power.
When the vacuum is one and the switch for on for the carpet position. There is a small button the the floor attachment which we call the power head. It will b in the place of where the head becomes L shaped its either black or red. Push the button while the machine is on. If it does not work call ur electrolux dealer and have them pick it up. Or call me I'm a dealer and can have UPS pick it up no charge for u 1-866-966-9350.
Sep 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
It does not ****
Greetings from GoVacuum.com,
It sounds like you have a clog in the vacuum cleaner somewhere. What you can do is remove the hose from the back of the vacuum cleaner and see if the changes the bag full indicator, and pay attention to the sound of the motor. If the motor starts making a high pitch sound as soon as your install the hose, this means that there is a clog somewhere in the hose.
If you can give me your model number, I can send you a parts schematic to your vacuum cleaner.
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
228 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
