Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium 120
How do I go about to replace the Oven Cavity T.C.O. without taking the microwave down. Do the guts slide out?
No they do not. I just replaced one of these they aren't hard but it would be very difficult to do without takeing it down. due to the price of these I strongly recomend you call your local appliance service
Posted on May 20, 2008
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
It suddenly stopped working, no lights.
you have either a cavity thermal fuse or disk that has blown, you will need to take down, take all the screws holding the panel on, then remove the cover and the disk will be on the top left side of the unit, it may have burnt terminals on it also, you will need to replace those also.
Feb 23, 2011 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Can"t find a replacement model
Ge customer service should be able to tell you waht model is a "drop-in replacement" for your model.
Just be sure to give them, the full model number found on the tag inside the cooking cavity.
GE Customer Service is here.
Jul 10, 2010 | GE Advantium 120 Convection/Microwave Oven
How to replace light inside of Advantium 120 oven
I am looking for the same... How to replace the light inside the Advantium 120 oven. Any answers out there?
Jan 04, 2010 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
Replacing the cavity light on the g e advantiom zsc 1001
The bulb is a halogen type and there is a service kit that slighty changes the way it is mounted. It is not easy to get to from the top unless you do it for a living. Call GE Factory Service for the kit and a nice smiling technician to come out and take care of it. It may still be under warranty. 1-800-432-2737
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Power Out
Common problem with the Advantium. Culprit is a thermal cut off (TCO) for the cavity. Other posts detail where it is. I ordered a replacement at the link below.
http://www.mouser.com/search/ProductDetail.aspx?qs=i1kXDmddXkNuE3oXZkbuYw%3d%3d
Jan 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium 120 Convection/Microwave Oven Logo
121 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
