Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Jvc pos i just got home turned my tv on and the pic is out of wack, tried to mannually do the convergence but i could only do the red.......how can i adjust green blue and so on? thanks nathan
  • hiccups Apr 28, 2008
    My television has a shadowy picture with red fuzzy background. I spoke to a service technician and he said it sounded like a chip may be defective What type problem am I experiencing, and what is the most efficient and cheapest way to fix the problem.
When in manual convergence hit the select bottom to change to blue. as of green i have no clue.
Posted on Jun 07, 2008
I turned my tv on this morning and the colors were all out of wack. the tv was producing an image similer to what an old 3d movie with the red and blue images. i tried reseting the tv to factory default...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 48'' jvc colorconvergence is out of wack how do I fix this what part needs to be replaced if any
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK-392-120 IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 23, 2009 | JVC AV-48WP30 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence
convergence ic bad.
Jan 06, 2008 | Akai PT4298HD Rear Projection Television
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
JVC AV-48wp74 Red, Blue, Green
no you did the right move but now you align the new pc board ,try to get the service in to enter the convergence alignment section,on most jvc;s it sleep timer ,disply&video status to enter try it but if your not sure of that you can perform the alignment ask a tech to do it. on the remote certain keys do special functions and you need to know what they do or you might make it worse.
Aug 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Convergence problem on JVC
Convergence amp ic bad
http://www.hdtvoice.com/voice/showthread.php?t=28929
Aug 05, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Green Convergence out of wack
you got me stumped now. IC? Usually all components that make a video card work are made in the video card itself. You usually have to replace the video card unless you are a electronic specialists and have the tools to soder certain parts in and out of the board. Check n see how much a video card is for your unit. Might be fairly inexpensive. Wish I could help you more. Let me know the outcome.
Sep 18, 2006 | JVC AV-48WP74 48" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
