Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
I have a Playstation 3 hooked up to my Mitsubishi WS-65807 via component to DTV input. Picture is fine until game or blu-ray movie shows scene which is predominately white. When this happens, the picture begins to distort, like it's trying to adjust to anohter resolution, then goes blue with no picture. As soon as the source picture moves to a differnt scene that isn't mostly white, the picture automatically returns and plays fine until the next bright scene. This does not happen with pictures from regular DVD player, or Satellite 1080i HD-tuner. What the heck is going on?????
  • Anonymous Apr 22, 2009
    Did you get any feedback on this? I have a Sony and experience the exact same problem.
  • 3 Answers
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Posted on Apr 26, 2009
I have a Mitsubishi 65869 and had the same issues. Using DTV Input I can only successfully use 480P.
Posted on Mar 23, 2009
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
Model WS-65807
Reset the covergence to factory specs from the remote. Do it three times
Aug 10, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Apple tv
The component 1 and component 2 inputs only go to 480i and 480p. The Apple TV must be plugged into the DTV input which will accept a 1080i signal.
Aug 18, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
WS-65807 picture goes black when using HiDef Signal
Tank, If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue? please let us know..
Jun 11, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Picture looks whited-out
try to put only one input directly to ur unit using also the HD input, if the pictures is good, that means your switcher is ur culprit
Jan 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
817 people viewed this question
Top Televison & Video Experts
Electro Med Services...
