Question about Kitchen Ranges
Glass top range cookware
I just moved into a new condo that has a glass top stove and I need to know if I need special cookware for it and will metal pans hurt it.Thanks!
  • 5,911 Answers
Here's the recommended cookware for glass top ranges:
Aluminum and Copper - have good heating characteristics, but may leave metal transfer marks on the glass.
Stainless - may take longer to heat and may not heat as evenly (some stainless has a copper liner to aid in heat transfer). More resistant to leaving metal transfer marks.
Baked Enamel - great heating characteristics, provides uniform heating and resists marks on glass surface.
Cast Iron - NOT recommended due to the weight of the metal. Can cause potential cracks or breakage.
Now, any reference to metal transfer marks are merely disclaimers from most manufacturers that the potential exists that the cookware could leave marks on the stove surface. Using a good cook-top cleaning product after the surface cools will aid in removing any of these marks. This does not mean this cookware should not be used.
All cookware used on glass cook-tops should have flat bottoms. There should be no ridges, grooves, or warping. This creates an uneven heat transfer between the pan and surface and can potentially cause the glass to break. Most manufacturers will not honor a warranty where it can be determined that the consumer used the wrong cookware.
Make sure you wipe up any spills on the stove surface that contains sugars or milk. These ingredients (if allowed to burn on the surface and are not cleaned up) will eventually cause damage to the glass surface by either removing the finish or leaving pits and cracks. Wipe up all spills AFTER the surface has been allowed to cool using a non-abrasive cleaning rag or sponge. The green scrubbing pads are considered non-abrasive and CAN be used. DO NOT use steel wool or SOS pads! A small straight blade razor can be used to remove stubborn items by gently scraping in one direction. I don't believe you can use any cleaning product that contains ammonia either.
All of this information can be found in the owners manual that came with the appliance. If you don't have a user/owner's manual, post back with your model number and I'll see if I can locate it for you. I hope this helps you.
Posted on Apr 17, 2008
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
What kind of cookware is recommended for glass top stoves
Glass ones work best, but any heavy metal will also work. Heavy gauge not heavy weight. The lighter metal tends to bend and warp after a lot of use. If the bottom of the pans are not absolutely flat, these stoves will not heat the pan very well, which is why the glass cookware is the best to use, since it will not warp.
Feb 27, 2015 | Maytag 6.2 cu. ft. capacity electric range...
Scratches ceramic stove top
Good Afternoon Friend,
I understand that you have scratches on the ceramic stove top of your Frigidaire rage, model# FEF366. Small scratches do not affect cooking and will become less visible with time. To prevent any further scratches, make sure you do not use any abrasive cleaners. These can scratch your stove top even more. Try not to use cookware with rough bottoms. These can mark or scratch the cooktop surface. Try not sliding any metal or glass across your cooktop. This includes sliding your pans as well. Coarse particles such as salt or sand between cooktop and utensils can cause scratches. Be sure your cooktop surface and bottoms of utensils are clean before usage. I hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Frigidaire FEF366 Electric Kitchen Range
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
I BOUGHT SIEMENS E-NR.EH645TE11X/02 FD9009 00523 INDUCTION CERAMIC STOVE TOP , BUT I CAN`T GET IT TO WORK. WHERE CAN I GET INSTUCTIONS ON THE WEB HOW TO USE MY STOVE, AS THE INSTRUCTIONS ARE IN...
Are you sure that you are using the proper cookware.It has to be steel can be tested with a magnet against the bottom of the pots and pans.. Many places advertise it as induction ready cookware.Glass and aluminum will not work at all .
Jun 09, 2017 | Kitchen Ranges
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Glass top stove hard to work
Glas tops usually detect both heat and time of unit on cycle. notice how burner turns on and off when on lower settings. the biggest issue i get on glass tops is cookware. the cookware should "FLAT!!" bottoms, owners manual suggests using a straight edge to determine. I have tested very expensive cookware ($200 a pot) and it seems to not be flat enough. much expensive cookware is designed to be used on gas tops. pans should also be of a medium weight. I tell people before they buy a glass top, plan on spending nearly as much on your cookware as on the range. A good set of Calphalon (not an advertisement) non-stick is about $500 -$600.
The top has built in sensors that shut the burner down when heat is trapped in an air pocket under the pan. this causes the burner to shut down prematurely and take much longer to cook.
Jun 14, 2008 | KitchenAid KESS908SPS Electric Kitchen...
Can cast iron be used on GE glass top stoves?
Cast iron is not recommended due to the weight and its heat retention. Cast iron stays hot longer and, due to the weight, can damage the cooktop surface by scratching or cracking it. In your owner/operator manual there should be a section that defines what type of cookware that can be used. Aluminum and Copper heat rapidly, but can leave metal transfer marks. Stainless takes longer to heat and doesn't always heat evenly. Baked enamel, I believe, is the recommended cookware, because it is light weight, heats evenly and has a less risk of damaging the cooktop.
NOTE: References to any remarks about metal transfer marks made by cookware are DISCLAIMERS letting the consumer know that the POTENTIAL of marking the cooktop surface exists. This is NOT to imply that the cookware should not be used. There should be clear instructions that state how to remove the marks (if it occurs), what recommended cleaners are to be used and how to properly keep the cooktop surface clean. Spillage from milk or sugar substances can cause more damage than metal transfer marks.
Another item to note is the cookware bottom should be smooth and flat. If you sit a pan on the range surface and it does not sit evenly, you can potentially crack the cooktop surface due to uneven heating.
A warranty in most cases does not cover damage or breakage of the cooktop caused by the consumer using improper cookware or dropping something on it and breaking the surface.
Not trying to give you a lecture here, just trying to give you some advice just in case you weren't aware. I hope you find this information helpful.
Apr 09, 2008 | Kitchen Ranges
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,019 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
