Question about LG 42LC2D 42 in. LCD HDTV
Legend 30 inch lcd sound but no picture
I have a legend lcd I have sound but no picture can you help
  • Anonymous Apr 21, 2009
    when I turn on my tv you hear sound. Sometime the picture may show for about 1- 3 minute then the tv go black no picture.
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Legend LCD tv power issue
the problem is inside th vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 mf 10 v capacitor . little bit of soldering/de soldering skill is needed . cost of cap 0 dollars got it from old radio. ernie
Feb 17, 2009 | Televison & Video
Legend LCD LC1916L TV Picture
If you unplug the unit from wall plug for ten minutes, it should reset the picture. I would unplug the a/v cables also in case of a ground loop
Feb 29, 2008 | Televison & Video
Lcd tv picture problem
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
Lcd tv
i have the same problem which im guessing is the tv itself because i tried both hdmi ports with two cords and the composite cables but still same prob. so i have no idea what could be causing this
Nov 29, 2007 | Televison & Video
Sound but no picture
I had the same thing happen, replaced the backlight inverter and it works fine. I got mine from http://www.lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=V144-001MSS.
Nov 25, 2007 | HP LC3040N 30 in. HD-Ready LCD Television
LG 42LC2D 42 in. LCD HDTV Logo
158 people viewed this question
Computer Repairing
Computer Repairing
