Download a free manual from www.brother-usa.com and under support and put in your model number. E6, means that the thread is tangled, totally unthread it, now with the presser foot up, rethread, pull the top thread, now lower the presser foot and pull the thread, it should barely move. This will seat the thread in the tension discs. Read your manual before using, it will save you lots of grief. People love to skip this step, and wonder why the machine is not working right. This is one time you should take the time, it is worth it.
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
Go to www.brother-usa.com and you can download your manual for free or call them, Your E6 message means that you have a thread tangled and you must get it out of the machine, totally unthread and brush bobbin area and feed dogs then, unplug and it will reset, then plug in and rethread,
Hi! The E6 error means the thread is tangled. I suggest you completely unthread the machine, including the bobbin. clean out any lint or bits of thread in the bobbin area, and carefully rethread.
Hope this helps!
Robbie
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
