Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
Chamberlain silent 3/4 hp red led on side and hear beeping sound garage door opens and closes, but the beeping sound is annoying? what is causing it
    Scholar:
  • 143 Answers
This beeping is actually the battery back up unit making this sound. It either means there is no power to the outlet and it is using stand by power or that something is wrong and the battery is not charging correctly or will not take a charge. You can order replacement parts at chamberlain.com. Thanks BB
Posted on Sep 03, 2010
    New Friend:
This battery is an excellent example of inventing a fix for a problem that is almost non-existent, and then selling you a part every 2-3 years that you don't need. How often does your power go out, and how long does it stay out? What are the chances you will need to open the garage at that moment? Even if that very unlikely event happened, may I suggest parking the car in the driveway until the power comes back on, or getting someone inside to open the door manually. Be a smart consumer. Don't buy their battery.
Posted on Nov 28, 2012
  • R Beck Nov 28, 2012
My craftsman garage door opener is beeping (2 hours). How can I stop it
Our garage door opener has a safety beam across the floor which prevents the door from closing on objects which are sitting there. This safety feature also makes an annoying beeping sound each time the beam is crossed. This tutorial will show you how to disable the beep, but still keep beam functional. https://www.youtube.com/watch?v=Cn_vGe_7_x4
Jul 14, 2016 | Sears Craftsman LiftMaster Chamberlain...
There is a beebing sound coming from the unit every 60 seconds. What can I do?
This sounds like the unit may be running on its battery and the battery is running low. Is the orange light also blinking? (The LED is on the side near the worklight so it's easiest to check if the light is off.) First check if the power is on to the house and then to the garage area. Next check if the garage door opener is plugged into the outlet. Make sure that the battery is properly connected to the wiring harness (and the opposite side of the harness is fully seated as well).
If the LED is red and the unit is beeping, then replace the battery for the opener. The battery kit is part 41A6357-1 for the WD962KD Chamberlain Evercharge model. The Chamberlain 4228 is a substitute battery kit and is available at Amazon and other vendors. It is a little harder to put in the opener (and then remove later).
If a new battery doesn't solve the problem (after 48 hours of charging), then the opener's recharging circuitry has failed and can't recharge any battery. Depending on the age of the opener, you may be better off replacing the entire unit.
The manual for the WD962KD opener is available from Chamberlain here: http://www.chamberlain.com/doityourself/pdfdocs/114A4249.pdf .
Please add a comment with your garage door opener model or check your manual to get the correct battery for your opener.
I hope this helps.
Aug 17, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
My chamberlan garage door opener keeps beeping
The only thing on a chamberlain garage door opener that can beep is the battery back up unit. It beeps if it is being used or if it has lost it's charge or if it has lost the power to be charged. There is also an led light that will give you information on the status up by the battery too. These will be in your manual to decipher. You can get a new battery at chamberlain.com Thanks BB
Aug 21, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Intermittent beeping sound
Check the main battery,it might be dead,beeping sound it a require a another battery.
Apr 14, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage opener/ brand garage master 1/3 HP
trolley is not attatced to the chain, grab that red rope that is hanging down and give it a ****. run the door up until it re-locks onto they trolley
Mar 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
2,184 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
