COMMAND SPECIFICATION ERROR, DETECTED BY PRINTER (816)
Using Olivetti printer, encountered this error.
  • karthik_a Oct 29, 2008
    I have the same problem, in oliveti
  • dwalter255 May 15, 2009
    I have the same problem too..
2 Suggested Answers
acdr
  • 1913 Answers
SOURCE: I Shared Olivetti printer between 2 workstation(Error)
then pls explain in brief.
Posted on Jan 05, 2009
Olivetti d-copia 16w error code H4
I need driver olivetti_d_copia_16w for winXp....
Sep 25, 2012 | Olivetti Office Equipment & Supplies
How do I do this?: Then put the machine in test mode with the key combo P-*-C-* and go to test command 14-Start to clear the code.
Please be aware that the 'key combo' P*C* that you've stated is a "simulation command". It is used by a service tech rep to cancel error codes or test the equipment for certain operation required of it. There are numerous numerical codes that needs to be input following this command plus a numerical sub code to verify action or test needed.
As for the command 14-start.... this is the code used to cancel most errors you may encounter during operation.
Feb 22, 2011 | Sharp MX-2300N Color Copier
Hi I have a problem with the printer Olivetti 300- the error number is C2250- is there anything i can do to fix it?Sylwia
This error is for network connection outage. You may check the network/data cable connection to the printer.
Nov 22, 2010 | Olivetti Office Equipment & Supplies
Use Printer Offline: Error Processing Command
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jun 07, 2010 | HP DeskJet 6540 InkJet Printer
Doesn't recognize the color ink cartridge
Good day!Your cartridge is the problem..even if its new or original if the printer never detected or sense your cartridge's presence..then that error will appear..
So,try to change a while or borrow if you have friends there just for reading or proven the problem..
mastergani
Apr 03, 2010 | Olivetti wireless All-In-One InkJet...
My olivetti anyway printer worked fine with my laptop,but will not work with my new pc,just reads no device detected
attach printer your new pc. pc on and printer power on. detect your printer than install driver in your new pc through printer driver cd.
if no detect your printer than right click my computer than properties than hardware than device manager than select any and top option scan for hardware changes, detect your printer and install driver.
Mar 02, 2010 | Office Equipment & Supplies
I am not presently using my Brother MFC 210 usb printer but upon booting each time the command reads.... brsvc 01 encountered problem. need to close. The error signature reads... sz App Name brsvc 01a.exe...
This problem is widely reported and the only solution I know of is to rename the file in Windows/system32. BRSVC01 will no longer attempt to load at start-up. BRSVC01 loading at start-up is apparently unnecessary. Renaming can always be reversed if you encounter any problem.
Dec 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
531 people viewed this question
jasbo
jasbo
