When powered on it cycles on then off, on then off.
unit is new was just recently turned on.
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure the other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strip as it may cause power loss. If you check around the silver contacts on the power adapter, there should be a green LED light on. If not, that's the cause of the problem. If it's on, plug it back in the printer in the right position and properly secure it. If it won't power on automatically, press the power button. If problem persists, the printer itself is the problem. If these are the cases, I suggest you contact Lexmark Technical Support to further investigate the problem.
