Question about HP Officejet 5610 All-In-One InkJet Printer
Not printing my hp5610 is making all the motions like it`s printing. the carriage moving back & foward but no ink. it`s a new cartridge. please help!! Ed. eosfinancial@gmail.com
  • Anonymous May 15, 2008
    I had this printer for quite a while and worked well. But yesterday it stop printing in black ink. The black cartridge is not empty. I don't know why it suddenly stop printing black. There is no error message either. Can anyone help?
  • Cash413 May 17, 2008
    Suddenly will not correctly. feeds paper in and starts printing halfway down the page. Self-test prints correctly
  • 123 Answers
When you placed the new cartridge in did you make sure to remove the tape over the print head?
Did you run a cleaning cycle on the printer?
I would try both of these things first.
Good Luck
Posted on Apr 17, 2008
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
How too change ink
Follow these procedures to help you get access the cartridge. This is taken from the online manual of Fixya. http://www.fixya.com/support/p378621-hp_psc_2210_all_in_one_inkjet_printer/manual-3472/page-58
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2.
After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3.
If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6.
Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7.
Please rate this answer. Thanks for using Fixya.
Aug 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
How do you change the ink carterage in an hp officejet 5610v all-in-one?
Hello !
To change the ink cartridge(s) in your printer,
Open the print-carriage access door by pulling it forward.
The print carriage moves to the far right side of the HP All-in-One.
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
When ever I start to print it sounds like automatic weapon fire. It seems to be coming from the ink cartridges...replaced both of those and still same issue. Help would be greatly appreciated as in this...
It may be that the carriage sensor is either broken or moved out of place. When you power on the printer, it will move the carriage back and forth to find the end sensor. If it doesn't find it, it will slam against the end and cause the sound you're hearing. Look on the side of the cartridge for a tab or ear and make sure that there isn't any obstruction in the carriage path that would impede motion. Also check to see if the sensor isn't out of place.
Mar 17, 2009 | HP Photosmart C4280 All-in-One InkJet...
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5610 All-In-One InkJet Printer Logo
52 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
