Wont boot teenager tryed 2 help! hardrive formated i think moved wires
  • Chris  Morse
    Chris Morse May 11, 2010
    Could you maybe put that into the form of a detailed question?
    Scholar:
  • 55 Answers
Please remember to always note Computer specifications and Operating system details when you post a problem and to explain your problem in more detail.
Kind Regards,
Stef
Posted on Apr 17, 2008
Error 8002f310 ps3
Ok I need to start by saying if youre doing it my way, you need another hardrive and a usb stick. If you dont have either, then youre outta luck or you gotta try the other ways posted around the forum. I will say that i just found out this has been posted up before on the us ps3 forum, but i have elaborated on it and i did find out the solution myself before i found that post.
Anyways HERES THE STEPS:
1) Download the ps3updat.pup file off sony's website. You need to make a folder in your usb stick called "PS3" and within that folder, a "UPDATE" folder, it must be in capital letter for the name. Then drop the ps3updat.pup file into the update folder. (If you have problems with this step, visit http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm)
2) Plug in "New/Temporary" hard drive into ps3 (For Slim - Theres a cover under the ps3 that you pop off and theres a screw that you have to screw off in order to access the hardrive For Fat - I think theres a cover on the side, im not sure i dont have the fat)
2) Boot into safe mode (Press and hold onto the power button untill you hear the double beep, then let go of power button), follow on screen instructions, and select update firmware. Follow the on screen instructions and insert your usb when prompt to. Let it format your temporary hard drive and let it install the firmware. When its done installing the new firmware on your temp hardrive and gets to the language selections, internet settings, etc screen, you can choose to continue and finish them off or turn it off at this point.
3) Now with the ps3 off, put back your original hardrive in and boot up your ps3. Once booted up, it wont be in the update loop anymore! But instead it will tell you that it cannot boot up system due to firmware difference and must be updated. Plug back in your usb if you took it out, and press start and select at the same time, to continue with the firmware update. NOTE!!!! Most likely you will experience what happend to me. It will stay at 99% for awhile... so dont panic, it will go through! And thats it! Your data should be intact, you would have saved 150 dollars for repair, but most of all, your firmware is updated!
Nov 24, 2013 | Sony Playstation 3 (PS3) Console
Hello, I have a problem with my computer, I think all started with a virus when downloading a program to diagnose the pc or a driver for the modem, try removing the virus with several antivirus with no...
I think you just erased your hardrive. (Or it wouldn't show the Operating system not found message).
That means your data is already lost. (Unless you have 2 harddrives in your pc)
Get a Windows Installer CD from a trusted source. ( Maybe the local computer store can lend you one)
Test this cd on another pc (By just booting the cd , not by running the installer!)
Install Windows using this cd (Start it using F12 like you said)
May 15, 2011 | IBM Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
Why wont my laptop fromat?
i would first attempt reinstalling windows with your system restore disk, but if you opt to format first the parameter you are missing is the drive letter, which would be C:\
Mar 22, 2010 | Gateway 450ROG Notebook
Trying to format the hard drive but can not find device drivers or partitions
If you have access to another computer, download Gparted BootDisk
This will boot on any system and allow the format assuming the hard drive is actually working
Oct 12, 2009 | Computers & Internet
NEED WIZ"S HELP- CANT BOOT XP OR VISTA CD FROM DVD DRIVE
I'll give a whack at this problem. I think the previous person meant blank drive NOT black drive (that doesn't make sense to me).
I would follow the previous persons in going to BIOS and making sure the first boot device is CDROM. My question to you is whether you've already done this or whether you need assistance with this process. If so, please tell me what computer model you have.
Dman
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA
dont mind it...
if you want to install xp to your computer while you are using utimate vista you can install it...
but you must have a large space of memory to install xp, tnx anyway hope that i can help...
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Hardrive Partition Is corrupt
As i review your explaination, there might be a problem in your hard drive. There so many problems i encountered in the hard drive i encountered like that. However, some problems can be fix using your solution and the other can be fix by replacing the BIOS Battery, and sometime the error in the hardrive is cause by a memory fault. If you are sure that the memory, motherboard, and the bios battery is good and working properly. I recommend you to replace your hard drive that the inconsistency problem will be fined.
Please do testing of your hard drive by connecting it to the other system.
Feb 01, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
