I purchased a new computer but i am unable to connect to the internet with my wireless adapter because it asks me for a security password that i never established when i initially connected my router and wireless adapter.
  • 67 Answers
Try using it without actually entering a password. Othewise, connect a computer to the router with an ethernet cable. Go to Start> Run> type cmd a black window should open up. Type ipconfig at the cursor. This will bring up a series of numbers. Try connecting to your router By typing the ip address that is in the "default Gateway" spot, in your browser address bar. If it has a login page, use "admin" as the user without a password and change the settings in there. You should be able to disable the password there.
Posted on Apr 17, 2008
Why can't my dell inspiron 530s desktop install
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
Dec 19, 2012 | Computers & Internet
Unable to connect to my wireless internet connection on laptop
you could try updating your wireless network driver. click start and right click computer, click manage and then device manager in the computer management window. look for network adapters in the main window and click to open drop menu. find the wifi adapter, right click and click update driver software. you will need to do this via a wired connection
Mar 08, 2012 | Samsung P30 Notebook
Passphrase for belkin 3DDD USB Drive
The Passphrase will be saved in the Wireless Router ...
not the USB Adapter
IF you are using a belkin wireless router you can retrive your passphrase as follows
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
Regards
TOM
Dec 24, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
I have a new laptop computer and am wondering how I log on to internet as it is asking for my access/security code?
I assume you are connecting thru wireless or wifi. If its asking for the security code then you have to know the security password for the SSID on that wifi router. Many Wifi routers have security passwords before you can access the internet. If you are connecting to your wireless router then just disbale the security password but will be disadvantageous because other people can connect to your router. Just ask the person for the password who initially setup your wireless router.
Nov 05, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
Connected but unable to view website
You might need to check the security on your router , if its enable or not.
You can try the solution below to check your router wireless security. Note this should be done on a computer that is connecting to the internet thru the router.
1. open browser and enter http://routerlogin.com
2. username is admin , password is password.
3. click on wireless option .
4. look for the wireless security settings.
If you dont have another machine that is connecting to the internet. Just follow the steps below.
1. Reset your router for 30 seconds by holding the reset button.
2. turn off for 30 seconds after resetting it.
3.Power off the modem and turn it back on after 2mins.
4. If all the lights on the modem is stable power on the router, make sure the modem is connected to the internet port On the router.
5. check your computer which has a usb adapter,. Look for the wireless icon, You should be seing an option were in it will allow you to view the available wireless,
6. Look for the wireless name "netgear " and press connect. CHeck if you have internet.
Rate me if the solution is helpful
Kevin angell.
Jun 14, 2010 | NetGear WGR614 Wireless Router
I bought a new Toshiba Satellite L550D-11N
Unfortunately you have to know your security key, it's there for your privacy protection, like passwords to your e-mail or other services.
You have to ask the person who set up the router about the password (key), or ask that person to change it to a new one - and this time write it down and put in a safe place, where you can find it in the future, like on a piece of paper pasted on the router box.
If you change the key on the router, and have other computer(s) using this connection, you will have to re-enter the new key on those machines.
Jan 05, 2010 | Toshiba (PA3070U-1MPC) 802.11b Wireless...
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Can't connect home comp to laptop
how many wireless computers do you have?
is it a dekstop or laptop?
if desktop have you installed a wireless adapter? if laptop, is it using a built-in wireless adapter, have you enabled the wireless adapter or have you installed a wireless adapter?
please make sure first that the wireless adapters are installed properly or enabled on your computers, if everythings OK.
access the setup page of your router and change the wireless settings of it.
how to access the ui
- open the internet explorer
- on the address bar type in 192.168.1.1 hit enter
- enter admin under password, leave it empty for the username and click ok
- click the wireless tab
- set the wireless mode to mix, change the wireless network name or ssid with any preferred name you want to use, make sure to enabled the ssid broadcast and then click save settings.
- after that, under wireless tab, there are sub tabs, click wireless security
- set wireless security to WPA-PERSONAL, and under passphrase, enter your desired password for wireless connection, take note of it and please be reminded that its case sensitive.
- click save settings.
for your wireless computers, if adapters enabled and working fine, on the system tray you should have an icon for the wireless connection, doubles click on it and it will pop for the wireless connection window wherein you can see the name that you set on your router, all you have to do is select the name click on connect and it should ask you enter a password, enter the passphrase you set on the router and click connect. then check if you can go online, if yes do the same thing with other computers.
Have a great day ahead.
Sep 28, 2008 | Linksys WRT160N Wireless Router
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
New Laptop Will Not Connect
The first thing u need to do connect ur router to the computer with a wired connect access the router page (firmware) ip address which need to enter to open the same on internet explorer is 192.168.0.1 enter the user id & password of router (default user id & password is admin or password)
step 1 go to wireless change the channel to 6 (this the best channel)
Step 2 go to add/remove in control panel remove the dell wireless utility
step 3 go to device manager in control panel go to network adapter right click on wireless network adapter & select uninstall or remove
step 4 Now click action on top of device manager & click on scan for hardware changes it will reinstall the driver
Step 5 now go to network & sharing center go manage network connection right click on wireless network connection & select the connect it will show the list of wireless network now connect to ur network enter ur security key once ur connected save the network & ur issue is resolved
Jun 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
David Payne
David Payne
