HI. This is basically a thermistor code. This object is very important and the unit will not function correctly if the circuit is open. Due to the fact that you have the code present; this will confirm that the thermistor has failed(open circuit). This will require you to have the thermistor replaced, asap. Once replaced; the unit will operate properly.
The suspect component will be mounted inside the unit on the blower housing or vent assembly. This is the principle temperature monitor.
That code is for the thermistor. It usually means that you have to replace it.
E1 Message indicates that this the time to call for service, call toll-free Customer Care Center for service 1-800-253-1301(all over)
1-800-807-6777 (In Canada).
Good luck and have a nice day.
