Question about Linksys Wireless-G WRT54G Router
Removing security from a wireless network - Linksys Wireless-G WRT54G Router
    Genius:
  • 1,027 Answers
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
  4. After the "Setup" Page loads, click on the Wireless tab.
  5. From the "Wireless" area, click on the Wireless Security sub-tab.
  6. When the "Wireless Security" area opens, select the Disable option for "Wireless Security" option
Posted on Apr 17, 2008
I set up my Belkin N Wireless Modem and it has been working fine. Except I did not install it with a "password" at the time of setup. How do I put in a password now. I cannot find a program in...
Hi psheayn,
Kindy copy this steps in notepad and also copy the screen shot before u start doing it.
You can put up a wireless password manually b logging in to the router interface but you should be very careful because if you change any thing else it might be a messup your whole router so kindly do the following steps alone.
Step 1: Open the internet explorer
Step 2: Clear the address bar and just type the number alone which is 192.168.2.1
Step 3: You will get router screen as below
Step 4: In the left corner of the page under "Wireless" Security and select security mode as "64 bit WEP "
Step 5: Type any 2 numbers per box as u like and apply changes. Also make sure that you are gonna copy the password. If you want to connect any other computer in future you will need to have that password to connect.
Step 6: Under security in left side select "WPS or Wifi Protected Setup" and select WPS as disabled and apply changes. Dont worry it not related to security its just an option that has to be disabled if you enable the 64 bit WEP password.
Step 7: Then Connect wireless computer to the wireless network name and will ask for the password this time since password has been enabled. And ur router is gonna be a protected one and no one can hack it.
Step 8: In case if ur not able to connect to the network remove the preferred network and connect to it.
To remove preferred network
XP OS
Start -->control pannel --> Network and Internet connection-->Network connection --> Right click on Wireless network connection icon --> Select 2nd tab Wireless network --> Remove preferred network one by one.
Windows Vista/ Windows 7
Start -->control pannel --> Network and Internet connection -->Network and sharing center --> In the left side select Manage Wireless network and remove preferred network one by one.
Check out the screen shot to enable security on the Router and to disabled WPS
Nov 06, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have created too many wireless networks and only one is secure. i want to delete the unsecured ones and change the password on the secure ones.
To Remove the other Networks
XP :::
Goto control Panel -> Network Connections
Right Click the Wireless network connection and select Properties
Click on the wireless networks tab ( Top )
Under Preferred Networks you can find the names
Remove them and click OK
Windows Vista /Windows 7
Open Control Panel
Goto Network and Internet -> Network and Sharing Center
On the left under Tasks Click Manage Wireless Networks
You Can Remove the names by right clicking on them and Remove network Or Click the Remove icon At the top (-)
WIRELESS SECURITY ISSUES - To Change the Security - Key
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 25, 2010 | Belkin N1 Vision Wireless Router
My friends told me that wep security mode is less secured that WPA2, so I change my security mode to make it more secured, and my windows-xp was disconnected to the network and cannot connect anymore, but...
Just try to remove the preffered networks on your computer and reconnect your computer to the wireless network using the password that you just created.
Sep 19, 2010 | Linksys WRT120N Router
I have a sony vaio about four years old. I have had no problems connecting to unsecured wireless networks and software secured networks, but cannot connect to a router secured network even when I have the...
Try removing the preferred Network and try to scan and connect
ON Windows XP
Start --> Run -->ncpa.cpl -->Right Click on the Wireless Network connection Icon -->Click on Properties At the top click on Wireless network tab --> Remove Your Network name if you found there then Try to scan and connect again will work
Aug 05, 2010 | Sony VAIO (PCWA-A200)
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I hooked up my wireless router to my modum but no internet is going out to my laptop
Open the router's GUI with 192.168.1.1 if it is a linksys/netgear router login with username - leave blank password - admin for linksys router
Click on wireless tab on top- Select Manual - Wireless n/w mode - mixed, Network name SSID(Remove linksys and type the name you want to give to wireless network), Radio band channel- Std.20Mhz. Wide Channel - Grayed out,Std.Channel-6.2.437GHz. , Broadcast of SSID - Enabled,Save settings, Click on wireless security (Under sub tab of wireless) - Security mode - WPA - Personal - Type the password you want to create for wireless. Try to search for wireless networks and try to connect. At times you not able to connect - So try to remove the preferred networks from list.
Synario for win xp -
Start - Control Panel-Network and internet- Network Connections - Rt. click on w/l n/w connection - View available w/l n/w - Click on Changed Adv. settings - Click on w/l n/w tab in btwn the general and advance - Remove the prefrerred networks from list. And now click ok - come out from ever y window and click on the pop up whuich says network detected/One or more n/w found in range- Click on the w/l name belongs to you - And hit connect - Type you security key and all set.
At times you not able to see w/l tab btween general and advance -
Thn Click on start - type services.msc in run - Rt. click on Wireless Zero Configuration (Myt be last or second last option from list) Click on start- And now try to connect to w/l after removing the preferred networks from list.
Apr 01, 2010 | NetGear WGT624 Wireless Router
How to reset the security key of my trendnet tew-430apb 54mbps wireless access point?
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Feb 11, 2010 | Trendware TEW-430APB 802.11g/b (TEW430APB)...
How do I reset my security with the dlink 2310
  • Support site here http://www.dlink.com/products/?pid=470
  • User guide here http://www.dlink.com/products/?pid=WBR-2310&tab=3
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - 192.168.0.1 Enter the user name (admin) and your password. Leave the password blank by default. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 25 of the User Manual
You may need to remove any old wireless profiles you have on the PC/Laptops Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --------------- Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Oct 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
"security key/pass phrase"
Yes, it will set it all back to factory defaults
to set the security again on the router Support site for D-Link is here http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx In principle: Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1 Enter (admin) for the user name and also for the password. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
Dec 19, 2008 | D-Link Wireless
Linksys Wireless-G WRT54G Router Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
