Asrock P4I45GV R5 Motherboard Logo
Posted on Apr 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor black out
Pls help me my monitor is  black out and my hdd is not spinning but my cpu fan is working what can i do/
Anonymous
Level 2:
Scholar:
  • Expert 176 Answers
  • Posted on Apr 17, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
176
Questions
Helped
59367
Points
378
I think your cpu is not working, only the fan is working because of the supply of the power in the motherboard. Can you hear some noise or beeping when you open the computer. If you hear the beeping sound maybe the problem is the video card or the memory. Try to remove the video card and insert again to the slot. Remove also the memory and clean the memory slot maybe there is dust block the connection of the memory to the motherboard.
Hdd light does not come on during power up on toshiba l555d-s7005
If the screen stays black it means there is an issue with BIOS. It should load before the HDD ever does. Mother board issue or monitor issue.
Will not power down.
The RAM module/s maybe faulty.
Thake the RAM module/s to your friendly computer repair shop and get them to test the RAM.
2answers
When I try to start the computer I turn on the tower, then the monitor and while the blue light on the tower lights up the monitor say VGA no Input and DVI no Input. All cable are plugged in and the...
so the computer is dead, you never said dead. word
only video not working sometimes, (implied not stated clear)
Desktops are most easy PC in the word to diagnose and fix.
the monitor did not lie, there is no video sync, there for no video possible and then mon, goes to sleep mode,
we call that the black screen of *****.
black means the PC never texts or shows grapics ever.
that message you say is from the monitors brain and not the PC brain. dig?
steps:
1: PC not packed in lint ,stalling all those fans.; inside.
2: The PSU fan runs, and must pin and blow are (look it its grills)
if not the PSU is bad, or the is a short inside.(overloaded)
3: the CPU fan must spin and blow air (yes inside) an fins not packed in lent.,
4: CD/dvd eject button work>? PC on>)
5: HDD heard to spin?
the goal is to get BIOS working, (even with HDD removed BIOS works) so that is why a tech uses this rule to test any PC.
the bios keys are F10 or ESC, old to new PC.
if you hammer this key the screen will show BIOS.
there are many things to prevent the video card to work
do you have a video card there, does PC have 2 DVI jacks on the rear.? i cant see it so. cant advise you easy
see the 20 steps here, im not going to repeat them all
all are valid.
http://pcdied.com/black-screen.html#Basic-basics-101
11helpful
2answers
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
3helpful
I was just given a Motherboard with a P4 2.56Ghz processor, so I put into a case connected the power supply & my monitor cable, my cdrw drive and turned it on. I get no beeps and no display on the...
hope u r a professional, as u r aware of hardware hazards n minds to open up n dismantle the system..
however, plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
plz give higher priority to step 6 to 9..
always better to consult ur system admin/vendor....
Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
Wont post
after turning on wait for a moment.. about 5 mins. then press fn+f4
Boka monitor is black out
try to check the horizontal output
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
