Question about IBM E74 17" CRT Monitor
Pincushion problem.. my E74 has a pincushion problem. When i trace the fault, i found the TIP122 place at heat sink near flyback is short. When i put a new one, it can works only for a few seconds and get short back. i try put the 2SD2058. The situation is same. Diode, capacitors, FET in pincushion line is ok. Is out there anyone that power-expert technicion can help me? Show me your expertise. TQ.
  • malaytech Apr 22, 2008
    2sd2058 bukan HOTransistor, BU2058 baru la HOTransistor, 2sd 2058 biasanya ada di monitor Samsung sebagai pincushion control. Saya guna sebagai substitute utk TIP122. HOT utk IBM E74 ni ok x short jd x nk suspect B+ coil short. Guna flyback tester pun lampu hijau jaa. Kalau open kaki collector 2sd2058 display ok cuma melengkung mcm pinggang.
    2sd2058 is not HOTransistor, BU2058 is HOTransistor, 2sd2058 is use in Samsung monitor as pincushion control. I use it as a substitution for TIP122 in several years ago(if i don't have TIP122 spare). HOTransistor for IBM E74 is ok, not short, so i don't think the B+ coil is short. The indicator of flyback tester is green that means primary coil is ok. If i free the 2sd2058 collector's pin, display is ok but the shape is very thin....
  • 180 Answers
Hang cuba tengok B+ line. Check FET tidak pun cuba tengok B+ coil dh short kot.
Posted on Apr 17, 2008
  • Ajemy  Rashid
    Ajemy Rashid Apr 17, 2008
    2SD2058 is it HOT transistor.? Try to check the primary coil fbt.
    Probably it has shorted that causes the Horizontal Output traansistor to blow up.
RCA HD52W58 has a short somewhere in the deflection board
TL010 which is the HOT its attached to the heat sink directly in front of the flyback. Unsolder that and see if the fuse stops blowing.
Oct 21, 2012 | RCA HD52W56 52" Rear Projection HDTV
My Ibm monitor light blinks continously but nothing on screen and the is a clicking sound continously
There is a short within the HT section and this can be possible with the failure of the flyback transformer or the driver transisitor.
So if you are equipped please open the back panel and check for shorting on the driver, also when powered this can heat up which confirms that the flyback is shorted.
replace with the same type.
Oct 01, 2011 | IBM E74 17" CRT Monitor
Tv stop working, no picture, no sound. Is there a bulb or what?
Check for blown fuse, if so then check for a shorted horitzontal trainsistor located on a metal heat sink near the flyback transformer on the high voltage module. If those are ok, then you have a bad convergence board.
Sep 04, 2011 | Philips Magnavox 51MP392H Rear Projection...
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Changed tracking on vcr and got screen shrunk with black bands on top and bottom. Won't go away and doesn't go away when you unplug and plug back in, or when you disconnect VCR. Any suggestions?
I believe the TV may be at fault here. This aging TV has a vertical problem, The horizontal bans you describe are common on an aging Zenith TV. You need to find an electronic enthusiast to correct this. Tell them to resolder the vertical IC and replace those capacitors that are near and next to the vertical IC. And have them replace the capacitors in the power supply. They will include a 25 volt 100 MF cap and a 35 volt 22 Mf cap. These are located very near the STR 5041 regulator on a large heat sink. Have them replace the high voltage deflection cap that is about 200 volts at 1 Mf, near the flyback transformer. And on the other end of the board near two heat sinks (one of these is the vertical IC heat sink) there is a 25 volt 220 Mf cap that is dead by now. resolder any and all bad grounds. Please save this TV and give it the longevity it deserves. Thanks for asking and show a few hands of support.
Jan 30, 2011 | Zenith B32A24Z 32" TV
X box 360 showing error code e74
The e74 code is caused by one or more of the following:
Improper heat sinks and insufficient air circulation heat builds within Xbox 360's case.
The thermal glue that holds the video scaler (HANA/ANA) gets slightly out of place due to the increase in heat.
The e74 code is displayed as the scaler chip does not function properly and your Xbox 360 will not work.
I would recommend calling Microsoft's Techincal Support about this, maybe they can fix it. Their number is below.
Microsoft Technical Support(United States): 1-800-4-MY-XBOX (1-800-469-9269)
Jun 01, 2009 | Microsoft XBOX 360 ARCADE Console
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
Nov 19, 2008 | IBM E54 15" CRT Monitor
Tv dead
no problem
replace by same number.
but remember before you replace check the following.
  1. check for normal output from power supply.
  2. check components connected to flyback transformer.like capacitors & diodes.
  3. check for print short.
  4. while replacing h/output be careful to check heat sink compound & mica sheet normal.
  5. put on the set
  6. if still it blows then flyback transformer is faulty.
  7. hope this will help.
  8. good luck.
Oct 11, 2007 | RCA HD56W58 56" TV
Dell monitor E773C 17"
It sounds like this needs component-level troubleshooting, probably in the signal section. It might also be loose connections or residue of some kind in one of the switches or on the switch board.
Jan 04, 2007 | Dell E773C 17" CRT Monitor
Pincushion problem
My thoughts would be, was it a Sony OEM transformer or a generic type? If the latter, that is probably a likely suspect. Another thing would be misplaced wires or switches that could have been accidently moved while replacing the transformer. I have had some of these sets that had no high voltage, and all it turned out to be was a broken solder connection on one of the pins going to the flyback transformer. Usually, if the flyback is bad, the Horizontal output transistor would be also defective. It's also possible that in the process of removing the old flyback (fun job wasn't it?) you may have cracked one or more of the circuit traces in that area of the PC board.
Jan 01, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
IBM E74 17" CRT Monitor Logo
256 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
