Radio Communications Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my instruction manual for Ultra Mini Bluetooth Headset HF RENEGADE and it won't hold a charge
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Jul 02, 2010
Anonymous
Expert
Level 2:
Answers
149
Questions
Helped
35026
Points
467
Usually holding the power button for a while will get it to pairing mode and the default security code is 0000 . try it . and the alternative is holding the volume buttons to get it into pairing mode.
Sin cargador
Creo que el cargador es de mini usb y se puede conseguir en cualquier tienda electronica o de telefonos.
si no es mini usb, el valor del cargador sera mas que el valor de comprar un nuevo headset de bluetooth
13helpful
2answers
Need instruction manuel for Samsung HF 1000
Just turn on, the speaker will say " power on" then go to your phone, go to setting on phone till you reach blue tooth settings, turn it on, it will now discover available Bluetooth , now go back to HF 1000 bring them closer, now press and hold the call button on Samsung HF 1000 till you hear speaker say paring, now look at your phone, you will see HF100, click and you are all set !
2answers
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
I have it pair to my I phone ----but I lost my manual what are the buttons for?
Follow the instructions mentioned below to resolve the issue:
  • Charge the headset
  • Charge your Jabra VBT185Z until the solid LED turns off
  • (approximately 2 hours)
  • Turning the headset On and Off
  • Press the answer/end button until you see a burst of flashes on the
  • indicator light (LED) to turn your headset on or off.
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
For online pairing assistance visit www.verizonwireless.com/bluetooth.
Hope the above steps allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
4helpful
Lost manual h700c...how can i get a password to sync?
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Maual for Motorola H350 bluetooth headset
To pair your bluetooth with your new phone...
Step one: make sure bluetooth is fully charged. While off, press down and hold the mulitifunction key on the bluetooth until light remains on.
Step two: put your phone in discoverable mode and click on add new device to search.
The phone will then find the bluetooth.
139helpful
5answers
232 Plantronics bluetooth manual
flashing purple after you hold it for 3 seconds is discovery mode. blue flashing is active on. hold for 6 seconds to turn off. hold for 2 seconds to turn on.
19helpful
Alcatel universal bluetooth headset manual
I don't know if this will help but try this:
Make sure the headset is charged up.
On your phone, go to settings and find the bluetooth set up. Don't start it yet.
on the headset, press and hold the on/off button until the light comes on. It should flash blue and orange.
Now press the "add device" or similar language on your phone. It will search for the headset. Once it is found it will ask for a passkey. Try typing in 0000 (that is, four zeros). Press ok.
It should work now.
25helpful
3answers
Need a users guide (instructions)
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
22helpful
4answers
BT pairing code
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
