Porjector My porjector is diplaying a yellow and blue shadow on the picture, the blue shadow is diplayed on all black areas of the picture, the yellow is in lighter areas. These shadows are only vertical with the blue on the right and the yellow on the left. What can this be caused from and is it repairable? please help i have tried researching this for weeks without any answers Jamie
  • 5 more comments
  • RLBrooks139 Aug 14, 2008
    Our Sharp xr10x show a pink image after connecting to the laptop but the image is normal color at the start up. I noticed some flickering the last couple of times we used it and tonight it turned to an image that was overlaid with a pink shade. We tried a different laptop and it still was pink after the projector found the computer.
    Rick
  • geodude69 Aug 26, 2008
    I have blue streaks showing up on a dark screen and yellow blobs showing up on a light screen...... changing the lamp has not helped,,any suggestions ?
    Ron
  • Mark Hansel Nov 23, 2008
    across top of screen on dark pictures have blue tint coming through like a haze what can i do to fix i can buy every part for this projector. Thanks for any help.
  • cslipp Dec 07, 2008
    when we first power-on the LV-S3 the image is fine but then a blue haze or shadow slowly spreads in a portion of the left-middle of the image.  changing cords makes no difference.  i should probably add that there is also now no color whatsoever when we use the video setting - we are using the computer/component setting for input.
  • gtoland Dec 19, 2008
    Panasonic PT-D3500U was working fine - suddenly, it has a pink hue cast over the entire screen and about two layers of ghost shadows extending to the right of each image on the screen.
  • westw Jan 09, 2009
    I have a yellow shadow to objects on my screen and also the yellow on the left and blue on the right. When you are off the the right of the screen it looks ok but when you are lined up with it or close you can see the shadow.
  • quiver Jan 11, 2009
    When I turn on my projector I have a yellow box that covers the 95% of the screen without a picture with the bright blue on the edges. I have dis-assembled my unit and found a lens/thin piece of glass that is mounted on a removable plastic frame. Viewing through this glass I see the outline of the box that is projected. The edges seem to be a darker color that would resemble the blue edges. Does anybody know where I can get new /replacement glass slider? My projector is a Mitsubishi HC3
  • 563 Answers
Hi there
Is it a LCD or DLP ?
First try using a different cable. If the problem stil occurs this might be a faulty Mainboard - which would need either repair or replacement.
Does the discolouration show in the startup screen as well ?
Posted on Apr 17, 2008
My new kyocera taskalfa 181 copier diplay call service c3100
please unlock the 2 scanner lock on top left side of the machine. the lock will be in yellow colour and it will covered by red tape.
Sep 20, 2012 | Copystar Kyocera Taskalfa 181 Copier
My lg lc230wo1 lcd diplay is black upon power on. led first yellow and then green
You may have bad backlight inverter board or the main power supply is not suppling the power (around 24vdc) to the inverter circuits.
Oct 28, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Display shows dark shadow around the center
Have you checked your lens assembly? maybe loose, or the bulb may not be seated correctly giving on out of focus image.
Feb 01, 2008 | ASK Proxima C180 Multimedia Projector
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Hit 53UWX10BA
Check you cable box compared to another tv.  The pisture may need adjusting take off front panle and use the screws to adjust pic  it could get better of worst be carefull
Oct 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
1,034 people viewed this question
k24674
jasbo
jasbo
