When you turn on the washer err loc shows up - Washing Machines
I tink the key lock may be turned on. I don't remember what button you have to hold in on that unit to turn it off, but it should be labeled below it.
Posted on Apr 17, 2008
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
Have a kenmore front load washer and shows pau 45 in the display. Whatever button i press shows err cannot do anything with the machine.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2010 | Kenmore 46462 Front Load Washer
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
MY WASHING MACHINE THEY DONT START WHEN I PUSH START IT SHOW UP THE WORDS ERR AND LOC
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Jul 02, 2009 | Kenmore Washing Machines
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
