Question about Lexmark X4270 All-In-One InkJet Printer
HAVE LEMARK X5070 ALL IN ONE
ERROR MESSAGE COMES UP WHEN I TRY TO SETUP FAX. SAYS MOVED OR DELETED.
  • Anonymous Jun 23, 2008
    i have a lexmark x5070, cant set up the fax , how can i set this machine up
  • Anonymous Dec 14, 2008
    any solution?
My printer cant work when it rain and now it cant print =(
Posted on Jul 14, 2008
Can send fax but not recieve them
Posted on Jul 01, 2008
Lexmark x5070 says cannot download application list when I try scanning something.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Sep 17, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I get a remote fax error when trying to send a fax...i have a Lexmark X5070 all in one printer/fax
The problem could be due to the quality of the telephone line connection. Try to resend the fax.
Lower the transmission speed. Follow the steps below:
  1. From the printer operator panel, press Fax mode.
  2. Press the menu button.
  3. Select Fax Setup.
  4. Select Dialing and Sending.
  5. Select Max Send Speed.
  6. Lower the speed to 9600 bps.
  7. Press check button.
Try to send a fax to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Turn off ringer on my lexmark x5070
To turn off the ringer on the Lexmark X5070, go to Fax Mode then press Menu > use the arrows, choose Fax Setup then hit check > use arrows, choose Ringing and Answering then hit check > use arrows, choose Ringing Volume then hit check > use arrows, choose Off then hit check. To re-enable the volume, follow the same path. Hope this helps.
Jun 27, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
While sending fax i get an error message remote fax error? what does this mean
Sounds like a problem with the receiving fax machines phone line. Try send to another fax. If it is still doing the same thing, then the problem is in your line.
Jul 24, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Lemark 5400 can't faxor rec fax give phon lone error message
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Jun 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Error message 1203 on Lemark X4270
Does your unit have a printhead cleaning manager. Do this a few times. Check to see if you have to reset ink levels too.
Dec 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Lexmark X4270 All-In-One InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
