Question about Singer 7462 Mechanical Sewing Machine
Having problems threading bobbin is winding too loose in addition the stitching is not form ing properly it is loose straight stitch on toop and under from the bobbin it is only forming loops .I have an older model and have misplaced the manuel its model number 237 singer canada charges 15.00 us or 20.00 cdn. although our dollar is at par or higher
  • Anonymous Aug 16, 2008
    bobbin not turning
  • Singer Master
  • 1,388 Answers
Sewusa.com may have a manual, but they will charge too. $15 sounds like a bargain compared to a non working "door stop"
Bobbin tension is probably loose because you have not followed the full sequence around the tensioners......this will compound sewing issues, however, what follows may be useful:
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
having problems threading bobbin is - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Nov 29, 2012 | Janome Jem Silver 662 Mechanical Sewing...
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Having rethread the spool it is now stitching but the underneath stitch is still loose
Did you thread with the presser foot up?
This opens the tension control so the thread can enter.
When the foot is then lowered to begin sewing, the thread will have the correct amount of resistance to form a proper stitch with the bobbin thread.
May 08, 2010 | Singer 5070 Mechanical Sewing Machine
Tension issues with the bobbn area
No, I have not had a consistent problem with this.
What looks like a bobbin issue could be a threading issue.
If a sewing machine is threaded with the presser foot down, the tension control does not capture the thread as it should. The top thread then cannot form a proper stitch with the bobbin thread.
If I forget to have the presser foot up when I thread, then I get loose stitching on top and loopy stitches on the bottom.
Mar 30, 2010 | Janome 659 Mechanical Sewing Machine
I do not have a users manual for my janomeHF107 and I am having trouble with the bottom stitches looping. the top stiches look fine, but the underneath stitches have loops. I have tried everything i can...
Raise the presser foot before threading the machine.
What looks like a problem with the bobbin thread is usually due to the machine being threaded with the foot down.
Foot up - tension control opens; foot down - tension control closes.
When the tension control is closed, the thread cannot enter as it should and then cannot be controlled to form a proper stitch with the bobbin thread.
The Singer Sewing Co website has many graphics that are the same for all sewing machines - you can check there with regards to winding, inserting the bobbin into the case/shuttle and bringing up the bobbin thread.
Mar 01, 2010 | Janome HF-107
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Singer 7462 Mechanical Sewing Machine Logo
155 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
