Question about Kyocera Mita FS-1030D Laser Printer
Flashing Light The third light from top keeps flashing. What does this light mean? i have opened and cleaned the printer, made sure that the tonner is added correctly and it all looks fine. When i turn the printer on/off nothing happens (normally there is a sound indicating that it's lineing up).
  • Anonymous Sep 30, 2008
    same problem as listed, with a solid light with the flashing below it, doesnt appear to be a paperjam anywhere in the system, checked all the usual hiding holes
    Problem Solver:
  • 6 Answers
Hopefully just has a jam. Usually people miss them under the process unit (toner) or behind the paper tray. Pull all the way out and look. If you have really looked everywhere you probably have a sensor out of place or dirty.
from manual-- Attention - Flashing  A paper jam has occurred. The cassette is not inserted properly or the paper has run out.
also read page 22-27 in your manual for jam removal
Posted on Apr 17, 2008
Keeps flashing up error and light a b c keep flashing
you either have a paper jam or the scanner module has jammed. open the printer and check the paper path for possible jams. then open the scanner lid and make sure the scanner light bar is in the home position at the end of the scanner deck and not stuck mid path.
Feb 27, 2012 | Canon Office Equipment & Supplies
The orange light keeps flashing
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
The light on the right is flashing red.
d40a83b.jpgCancel button
0de392d.jpgPrint cartridge status light
84e6616.jpgResume button and light
e1e1095.jpgPower button and light
- If the power light is flashing it means that your printer may be receiving data.
- If the resume light is flashing you may be out of paper, or you may have a paper jam, you may be printing a two sided document by hand and the first side has finished printing.
- If the print cartridge status light is flashing that means the top cover may be open, of there may be a problem with one of the cartridges.
- If all of the lights are flashing the printer may need to be reset.
Hope this helps.
Jan 06, 2010 | HP DeskJet 932c InkJet Printer
Check Printer Light Keeps Flashing on C3180 PhotoSmart
No, you do not need 3 cartridges or anything like that. Some cartridges have chips. Yours do not. If the light keeps blinking it means that one of the electrical contacts on the cartridge has blown and now the printer doesn't recognize it. Try printing something, you will get a message "problem with color cartridge" or "color cartridge missing". That means that the printer doesn't recognize it. I suggest you buy a new one. Or, if you have an old one, try putting it in and see if the light still blinks.
Jun 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
GReen light keeps flashing and my printer wont print
two options
1)either any of the printer cartridge is faulty.remove the cartridge and clean it with tissue paper.
2)or the printouts are pending in printque.delete all the printouts and then try .
any one of the above options will solve the problem.
if cleaning the cartridge does not solve that means it faulty so replacement of cartridge is necessary.
Apr 01, 2009 | HP Deskjet D2360 InkJet Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Paper Jam?
add toner or image unit waste toner full check page count. check switch in duplex section same one for the fuser exit.
Apr 30, 2008 | Kyocera Mita FS-1030D Laser Printer
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
Kyocera Mita FS-1030D Laser Printer Logo
292 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
