Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Nespresso essenza en90,o
Hi
do you know how to disassemble it. thanks
  • Anonymous Jan 04, 2009
    how can i unscrew them?
  • Anonymous Mar 27, 2009
    How can I disassemble a Nespresso D250. I'm not sure if the screws have hex heads or it I'm looking at rivets instead,
    Thanks
  • 23 Answers
I opened up my krups nespresso xn 2105 essenza C100N machine today. It was not starting up quick enough, so silly me decided to dunk it in hot water. My nespresso is an automatic, it has the on/off switch down in the back. My guess is the water that went in there is what is killing the house fuse now. So I really needed to open it up. Not knowing how to proceed, I looked at fixya first, No details yet. So here is what I did.
I looked at the screws, (post on fixya suggested they are screws) at the bottom. There is 6 of them. They look like rivets as if they have been made into round blobs after putting them in. So I took a dremel-like small grinder (a really small drill would do better) and made two small notches on the side of each one. Be careful not to chip away too much plastic of the machine ;) Then I used very small and long pliers to get them turning. That is actually easy, they are lightly set in plastic. Hard part is to keep the pliers from sliding off. Actually once loose the most of the turning I did using a narrow rubber tube, I guess you could use the rubber on the back of a pencil as well. So, remove 6 bottom screws, actually you can remove the sides now. This gives you access to the area where you can see all the wiring and many of the parts. For me I needed access at the bottom, so I removed two more screws near the bottom, and removed the bottom plate. The on/off switch for the automatic sits down the back of the machine, there is one additional screw (six pointed star shape) in the internals for this. I did pull off the switchy bit of the switch - do not do this as springs andcontacts fall out... Mine also still has water in there so I guess I found my problem.
Well, thet is how to dissassemble. I will have to find out how to reassemble tonight, to be able to get my wife het coffee in the morning ;)
Posted on Oct 17, 2009
Hello, pls help.... when I push the green button, it not work... the water cant flow out and no noise from the machine... what should i do??? heeelllppp
Posted on May 19, 2010
    Problem Solver:
  • 5 Answers
You can loosen the 6 screw on the bottom of machine,but screws which are especially
Posted on May 26, 2008
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
Jun 09, 2012 | Nespresso Essenza C100 Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
Jul 29, 2009 | Nespresso Essenza C100 Espresso...
Light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
Jun 21, 2009 | Nespresso Essenza C100 Espresso...
Too little coffee
reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Mar 22, 2008 | Nespresso Essenza C100 Espresso...
Help I Lost the directions
https://secure.nespresso.com/precom/manuals/pdf/C100_Zone1_EN.pdf
Dec 13, 2007 | Nespresso C100B Essenza Single-Serve...
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
2,409 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
