Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to restall from recycle bin
CARLOS R SOUZA JR
Level 3:
President:
  • Master 1,118 Answers
  • Posted on Jul 01, 2010
CARLOS R SOUZA JR
Master
Level 3:
President:
Answers
1118
Questions
0
Helped
305520
Points
3552
Open the recycle bin. Then, select the file you want to restore (or multiple files, through either Ctrl-click or Shift-click), right-click it (them), and select 'Restore'. It (they) will be moved to its (their) original location(s), prior to its (their) deletion.
Just my 2 cents.. Carlos
Where can I get the 8.14 gal. waste bin for an unidentified office shredder?
Trash Cans & Recycling Bins ' Staples®
www.staples.com/Trash-Cans-Recycling-Bins/cat_CL141928
Staples Inc.Use trash cans and recycling bins to keep plastic drink bottles, loose papers, and snack wrappers .... simplehuman® Slim Step Trash Can, Plastic, 10.5 gal.
13 Gallon Trash Cans : Trash Cans & Recycle Bins - Walmart
www.walmart.com > ... > Trash Cans & Recycle Bins
Walmart
I accidentally remove my recycle bin from the homepage . I need to restore it I don't see it anywhere in my computer though. Side note I do not have internet will I needed in order to restore it?
  1. Open Personalization by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
  2. In the left pane, click Change desktop icons, and then do one of the following:
    • To remove the Recycle Bin from the desktop, clear the Recycle Bin check box.
    • To display the Recycle Bin on the desktop, select the Recycle Bin check box.
  3. Click OK.
How to rename recycle bin
I'm am sorry I am a little confused, you want to rename the recycle bin Registry key, but not rename the actual recycle bin? I need a more detailed explanation of the problem that is very specific. Also, just out of curiosity, why do you wish to rename the recycle bin? I am just curious.
Ryan Frame
Creative Energy Associates Technical Center
2answers
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
2answers
Recycle bin got deleted
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Windows CE device
Windows CE device
Windows CE device
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
