Washer quit my maytag washer would sometimeas quit running in middle of cycle. now it has totally quit doing everything. it is still full and seems like it has no power but it has power going to it
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds llike a bad lid switch assy, not realizinf the lid is shut, for safety reasons wont run, can you hear any "click" just before the lid actually closes, it should be triggering the lid swith, if no t reppalce the lid switch assy, reall common issue
Posted on Apr 17, 2008
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
My maytag washer (about 4 yrs old) quits during rinsing cycle. I took the top off where the wires are to see what I could see. ;) The "buzzer non-adjust" zapped me when I touched it. Could this be what...
any time you touch live wires you will get an electric shock
always make sure you turn your power off before making any repairs.
more than likly the answer to your question is no that is not the reason why your washer stops mid cycle
it would either ne your lid switch causeing this and or if you can manually advance your timer to the next step. it is your timer that is failing.
please be careful
Aug 24, 2010 | Maytag Washing Machines
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Washer quit mid cycle
open lid pull tub to you till you hear a click(when you have an off balance load the tub will trip the switch)
Aug 22, 2009 | Maytag Dependable Care LAT9706
Hum's when I pull the knob out but nothing happens
I would check the pump for something small that is jamming it sometimes.
Apr 25, 2009 | Maytag LAT3600A Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Dead mav6000
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Mar 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
