Question about Arris Wireless G Broadband Router (wr850g)
Existing Hex key
Where do I find my hex key code? I bought a new laptop for my son and need to connect it but cannot find out where i wrote down the hex code
  • 77 Answers
Log onto the router via a wired machine, go to your wireless tab, security. Should be right there.
Posted on May 02, 2008
Macro Key Hex Code?
HEX codes are a base 16 numbers 0 to 9 plus A to F (DEC code are a base 10 numbers ie 0 to 9)
Go to this WEB site for a table of keyboard (ASCII) keys and the corresponding HEX key code.
http://brebru.com/asciicodes.html
Aug 21, 2012 | Computers & Internet
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
Just bought a new acer aspire netbook and have a d-link 615 router at home. my dell laptop connects automatically anywhere in the house. my desktop is hardwired so also connects no problem. this netbook...
If the netbook is running Windows 7 and the router is encrypted with WEP, then you can try changing the encryption to WPA or converting the WEP Key to HEX and entering the key in hex to the netbook
http://d21c.com/sookietex/ASCII2HEX.html
Dec 25, 2010 | D-Link DIR-615 Wireless Router
Where do I find my WEP key
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your change
Nov 21, 2009 | Linksys Wireless-G WRT54GS Router...
Headlights point down in son's 2002 audi TT...need to adjust them. Any tips on doing this successfully? No audi dealer near us here in rural nebraska. Thank you.
Hi, are the headlamps Zenon? If they are you will need to take the car to a dealer. If they are normal halogen lamps then you can adjust them with a 6mm hex key. If you look vertically downwards at the rear of the lamp unit you'll see the adjuster about halfway down facing up at you. simply turn with the hex key until you reach the required adjustment.
Hope that helps Matt..
Nov 15, 2009 | 2002 Audi TT
I forgot unlock code
This worked for me Thank Oxzgen from omgili.com
http://www.omgili.com/jmp/jHIAmI4hxg9kf_ixKeaBu9msccDGZfaj8Tp2CgQqtGDEJQ_7vJwV1ksniy7rGbKYY4PhKAtptB4XFO38fDtJZUxJoawCb1qPMpLJOL7AwKj0PSS6g60v9RGBmObIo2QKSHx5nJsiNCs-
OK... This is a little confusing and I didn't think it up (I wrote the part about HashCalc to adapt this method to the Juke). Here it goes:
Theres a number on the back of the phone: its 14 characters long... This is a MEID Hex code. It's not in the format you need to unlock your phone; you want ESN Hex which is 8 characters long. You need HashCalc (Free Program! Google it!) to convert it to ESN.
Pre.1) Open HashCalc
1) Set the [Data Format] (Drop-down box option at the top)
2) So you enter the 14 character code in the [Data] box.
3) Then make sure the box is checked next to the [SHA-1].
4) Then click [Calculate] at the bottom of the program.
5) Take the last 6 digits of the SHA-1 code.
6) Add 80 to the front of the code.
ie. Say the code was: 9a00297d20c0ef27c7afad981abbbad417045a64
Take the last 6 characters = 045a64
Add 80 to the front = 80045a64
This is the ESN Hex code I was talking about.
Now to convert the ESN Hex to your unlock code. I didn't make this part up...
7) Open your Windows Calculator (Sorry Mac Users!).
It's in Start Menu > All Programs > Accessories > Calculator
8) Set the calculator to Scientific Mode (in the view menu).
9) Then click the circle next to Hex to change to Hex mode.
10) Make sure your Hex mode is Qword (to the right of the Hex option)
11) Enter the 80****** code you created.
12) Change from Hex to Dec without clicking [=] or any other key.
13) The Lock Code is the last 4 digits of the Dec number.
Thats it! Theres your code. It worked with my Juke!
Apr 05, 2009 | Samsung SCH-U470 Juke Cellular Phone
I changed my samsung Juke from Nam1 to Nam2 and now it says initial programming needed and I am unable to unlock the phone. What can I do? My unlock code is not working.
Jan 13, 2009 | Samsung SCH-U470 Juke Cellular Phone
I have a linskys wireless G access point. Its working for my laptop but just recently my laptop said that my interent secuirty is secuirty enabled and that linkys is a unsecure network. What do I do? It...
jpconda - you did nothing wrong.
By changing your SSID, your connection broke, because you were still associated with your old SSID (linksys).
Right-click on your wireless network connection symbol in your taskbar and choose "View Available Wireless Networks". If you broadcast your SSID, you should see your new name in the list.
Just connect to it (and hopefully enter the security key..;-).
If you don't see it, go to 192.168.1.1 and enable the broadcast of your SSID ( on the Wireless Tab - Basic Wireless Settings). Don't forget to save your changes!
Once your are connected, you can disable the broadcast again, if you don't want someone else to "see" your network.
Jan 11, 2009 | Linksys Wireless-G WRT54G Router
Can't connect ibm laptops wep to wgr614
On my WGR under WIreless settings I have WEP, Automatic, 64bit, Key 1 checked, and a 10 character HEX key.
There is an SSID and when I log in via laptop, it askes for the key. I input my 10 character hex number and I'm logged in.
Carl
Dec 10, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Arris Wireless G Broadband Router (wr850g) Logo
74 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
