Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Leaking water, does not close - Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
  • arlingtonbad Mar 08, 2009
    i have a c100. it was moved from san diego to chicago in the original box and packaging and not sure why it's leaking out of the bottom. it's definately not the seal to the water compartment.
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Posted on Apr 27, 2008
My 1996 chevy silverado started leaking water what does that mean
Find the leak. Fill it, drive it, let it sit. The leak will be close to where it comes from. Radiator will be at the front of the truck, under the radiator. Water pump will be at the front of the engine, could be left or right depending on what it flows off of. Heater hoses will leak at the back. You just have to get under the truck and follow the water lines to the source. Or at least close to it. Fix it or you may have to replace the engine because of overheating..
Sep 07, 2014 | Chevrolet Silverado Cars & Trucks
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Suzuki VS 800 Intruder leaking water
Water leaks , have you closely inspected the header tank for cracks,leaks etc. Could be that once its hot the increae in pressure is causing the leak, look for any traces of old leaks which may have dried out by the time you stip things down
Apr 02, 2014 | 1999 Suzuki VS 800 Intruder
I top off my 1998 Nissan Altime's engine coolant evreyday. Also, the radiator fan stays on for appromiately 2 minutes after I shut the engine off. Is something wrong with the cooling system or the...
The fan running is normal. you need to find where the coolant is leaking. If there are no visable leaks. then suspect the radiator/reservoir cap.
Aug 14, 2011 | 1998 Nissan Altima
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leak. I dont think its the water pump but the leak is really close to the water pump
could be a hose but most likely its leaking water out of the weep hole in the bottom of the pump housing
Mar 11, 2010 | 2005 Dodge Caravan
Fisher Paykel GW52-F washer, leaking, but when taking the back off and partially filling with a bucket to test no sign of internal leaking, suspect water coming over the top, any suggestions?
Real good chance it is a split in the flexible hose from the bowl to the pump. When machine is working, the split opens and closes, but when not operating it can be closed up enough to prevent seeing it leaking.
Dec 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
1,209 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
