Question about Refrigerators
Danby silhouette Model dar604w freezing problem. Temperature shows "LE" instead of a temperature
  • muhammadishf Jul 12, 2008
    every thinf in refrigatraor was frozen, temperature shows le
  • Anonymous Feb 22, 2009
    exact same problem with mine!
  • 29 Answers
SOURCE: Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Posted on Jan 28, 2008
SOURCE: Keg freezing!!!!
I have had this product for 2 months and this just started happening to me also.
Posted on Jun 12, 2008
SOURCE: how to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Posted on Jul 06, 2008
  • 4 Answers
SOURCE: temperatuer gauge says LE
If your gauge displays LE, it is below 15 degrees F. That means your beer will freeze. The same problem occured on mine. I called Danby and the rep was very helpful. She informed me it was definately a problem with the temperature pad on the front of kegerator. The part cost less than $3 and shipping was $7. It was an instant fix and it was easy to replace. Remove the four screws to the tower on top, the three screws to the rear, and pull the top off. Flip it over and remove the two screws to the computer. Unplug the old and replace with the new. Very simple job. Due to the low price of the pad, I would order two. The shipping price is the same and I don't have to worry about another keg being ruined because I now have a spare on hand. Hope this helps.
Posted on Jun 15, 2009
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
I have a Danby fridge with a numbered temperature dial. Does the higher the number mean a colder temperature? All my stuff keeps freezing
Keep your freezer to the mid point, and your ref to mid.
Wait 24hrs for results. If your refrigerator is still freezing, you may need a new thermostat. Get the model number, and go to searspartsdirect.com and look up the thermostat. Sometimes it's also referred as cold control.
Apr 18, 2016 | Danby Refrigerators
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
My refrigerator keeps going into freeze mode instead of the temperature that i programmed into it.
if unit has a thermistat you need a thermistat if it has a digital diplay you need a control and thermistor. these are what controls the temps when they get to desired temp
Jun 03, 2010 | Danby Silhouette DWC512BL Wine Cooler
Hi, My Silhouette 63pint dehumidifier does not ...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 21, 2010 | Danby DDR600R Silhouette Dehumidifier
Temperatuer gauge says LE
Jul 24, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
How to reset the temperature on the danby silhouette wine refrigerator
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
