Washer won't drain - Washing Machines
  • 1 more comment
  • Anonymous Apr 28, 2008
    i haven't opened the back panel yet (top loading frigidaire FWX833AS1.)
    before i open the back panel, I'd like to know how to clean the drain pump.
    (the washing machine is full of water now, too.) eeeeek
    thanks! i'd really like to solve this problem myself, even though i'm not known for appliance repair.
    by the way...i can force the cycle to go to the final spin...but the water is still stuck in tub. all clues point to a clogged drain pump.
    thanks for any help!
  • flokolby May 13, 2008
    my GE spacesaver washer won't drain. It gets through all the cycles, but at the end it emits a burning wire/electrical smell and won't drain. It is only 2 years old, HOA of course won't assume any repsonsibility- and I rtotally don't have the extra money for service. WHaT do you think is the problem? NEed you and your expertise!! Help!
  • bklynbridge Feb 05, 2009
    my kenmore washer will not drain and will not spin i really need some help
  • 975 Answers
If washer works OK until it reaches the rinse cycle and then stops ?? then what you need to do is open the front panel or back depending of the brand , check where the drain hose is connected , your gonna look at a small motor that pumps the water out , it could be clogged , have it clean and it should be
working normally . hope this solutions works for you.
Posted on Apr 17, 2008
My kenmore washer is full of water and will not drain and also it will not spin
Posted on Feb 05, 2009
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
347 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
