Question about Apple iPod nano
Wheel and buttons not working
I got some water on my ipod although not a lot and I let it dry out. Everything is working fine except the wheel and the menu and play buttons. The center button works fine. The menu, arrow, and play buttons DO work to some extent like when i play a song i can go forward and backwards with the arrow buttons and go back a song when i click the play button.. but if it's not on a song the play button will not work. The wheel kind of works and will go back and forth between options but i can't do a full cycle through the options. It's a bit jerky. I've reset the ipod and restored/updated it already. Thanks for the help.
  • Apple Master
  • 13,433 Answers
Theres possibly some water in there, Id recommend takeing the ipod apart and drying very carefully so there is no water anywhere. you can use a hairdryer also.
but thats after you have the circuitboards and others apart, make sure you dont break anything while opening
http://www.youtube.com/watch?v=HRjLszFoNxU
dont get it too hot.
Posted on Apr 17, 2008
  • Ekse Apr 17, 2008
    remember you and only you are responsible for your actions, if you break the ipod I cant be hold responsible for your actions.
Dim backlight
Sounds like you need a new LCD. Simple fix for the experts.
Try either http://www.ipodrefresh.com or http://www.ipodrecharge.com. They specialize in ipod touch repairs.
Apr 06, 2009 | Apple iPod nano 4th Generation
Center button and click wheel not working on my ipod nano
Yes, well the exact thing it happening to me. What you could do and see if it works is this: Turn the Screen Lock on, off, and hold the center button and the Menu button. This will hard reset the iPod and use the origonal settings from when you first got your iPod. The second Tip: Take off all of the software, songs, games, ect. in iTunes and reset ALL the settings in iTunes. If this doesn't doesnt work (which it should), your iPod is broken and you need a new click wheel or center button.
Mar 27, 2009 | Apple iPod nano
IPod Nano 3rd Gen...click wheel seems to be frozen....
Hi, First find whether the Hold switch is in off hold position... ( Hold switch can be found at the botton or on the top of ipod) then try:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jan 13, 2009 | Apple iPod nano
Ipod nano 3rd gen. got little water on it and the backlight won't come on. replaced to screen and still doesn't. Everything else(Syncing, audio, video, and click wheel) works fine when it is on the...
Your first attempt to turn on a washed iPod is the critical one. If you're too quick to try to power it up and the water inside shorts out the electronics, you're done. You can try waiting until the iPod is really dry and power it on again; maybe it didn't short out the first time. But chances are, if you tried once and it didn't work, the damage has been done. There are several ways to try to dry out a soaked iPod….You can put it on a widow seal that gets a lot of sun for 2 days (that is usually your best bet but…I have even heard of people who have put their soaked iPod in a ziplock bag with kitty litter in it. For a few days…..You will more then likely need to do a reset on the iPod either way…..Here is a link to do the reset http://support.apple.com/kb/HT1320?viewlocale=e...) Good Luck and please leave me a rating…..Both ways worked for me…..dang thing is just too small and I forget to check my pockets all the time…
Oct 20, 2008 | Audio Players & Recorders
Nikon d200 sprayed with water
I would suggest that you give the contacts a good clean (gently of course) on both the camera body and lens'.
Also although the water would make no difference, make sure if you have any lens' with aperture rings to put them round to F33 or the smallest aperture, if they aren't this will cause the fEE.
Hope this helps
Drew
Oct 06, 2008 | Nikon D200 Body Only Digital Camera
IPod click wheel frozen
how do i unlock my ipod
Jun 05, 2008 | Apple iPod nano
Ipod Nano 1st generation
your PCB is cracked or there is debris under the wheel try placing a hoover on the jog wheel (DO NOT RUN IT OVER WITH THE SAID HOOVER OBVIOULY USE THE HAND TOOL) LOL
Jan 23, 2008 | Apple iPod nano
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Ipod Nano Second Generation
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod nano Logo
69 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
