Question about SanDisk Sansa e250 MP3 Player
All my music is gone
Paused my mp3 and it shut off like normal when I turned it back on it said that all my artist song everything was empty but when I checked my memory it said that it was full is there a reset procedure I can try or something else its a sansa e260R 4.0GB
  • Anonymous Apr 28, 2008
    the memory says that I have a hundred songs i the ipod but only 74 appears on the screen what can I do?
  • t3rr3l1 Oct 29, 2008
    my sandisk says refresh data base fail so all my song got deleted and I dose not want to work on the computer
Refresh database
Posted on Apr 17, 2008
All downloaded music is "unknown" artist, title etc.
Hey, I am not sure about ubunta but in Windows, you need a program that "tags" the MP3. Just google MP3 tag editor and you will find some programs that do this. Again, not sure about ubunta but give it a shot. What this program does is let you edit the MP3 to the fullest. Song title, artist, album, everything...Check it out....
May 30, 2009 | Philips GOGEAR SA6045 MP3 Player
Half of my music artists list is gone.
well your computer obviously has wiped it and doesnt have the artists there any more
Jan 17, 2009 | iRiver E100 Digital Media Player
Iriver e100 will not recognize artist/album
I too has this problem but if you search by Dir list you'll be able to see all artists and then select the able you require. Hope this works for you
Jan 05, 2009 | iRiver E100 Digital Media Player
My Insignia Sport Player MP3 says all music is Unknown?
I have the same problem with my RCA it occurs every so often. What I do is delete everything on there by useing he software that came with it and then change the mode from from MTP to MSC and back that way It formats it so Windows Media player( WMP) can see that it is really empty. Then I end the sync with the WMP and start a new sync. after that all I have to do is load the songs back on. This might not work for you since you have a different MP3, but if there is orginal software that came with it use that to delete. If you dont have any orginal software then you can still try to end the sync with WMP and see if that works.
hope this helps
Dec 31, 2008 | Insignia NS-DV2G MP3 Player
Song titles and artists still on e250 even after delete
if you've deleted all the music then just format the mp3 player then it'll all be gone
Dec 29, 2008 | SanDisk Sansa e250 MP3 Player
MY SANSA WONT PLAY SONGS, IT SHOWS ARTIST BUT STUCK IN PAUSE
Some songs are in the wrong format, or your DB is corrupt. Either way:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa Clip MP3 Player
Cant copy music to my MP3
Do you have WinXP /Vista, etc? OS = Operating System :)
Nov 14, 2008 | SanDisk Sansa e200 MP3 Player
Philips mp3 hdd183017
I should've bought an iPod, too. Try resetting it using the Device Manager (after backing up all of the songs), then put the songs back on.
Sep 30, 2008 | Philips GoGear HDD1830 MP3 Player
Everything is wiped out and so is the radio! Please help !!
The Music DB refers to the information (i.e. - Artist, Album, etc.).
The device need you to free up 6MB so it can create this.
Connect the device to the PC and delete several songs until you have at least 6MB free.
Disconnect it, restart, and youre all set.
Best of Luck.
Nov 03, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
136 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
