LCD HP 1730
Thanks for your help regarding the problem with the inverter circuit in my hp 1730 monitor. I'm also living in brisbane australia and was wondering if you would be interested in fixing the monitor and how much it would cost.
thanks, et
  • etniesza Apr 17, 2008
    Yeah thats awesome. Just say when and where i can deliver the monitor for you.
    cheers, et
  • butch3000t Sep 08, 2008
    monitr poewrs up then shuts down like there is no input after about 2 seconds
  • 472 Answers
Normally it is no more then $45-$50 total.
It will take about 2-3 hours but normally I reccomend a 24 hour period to allow for full after repair testing to ensure everything is running as it should.
Posted on Apr 17, 2008
HP 1730 driver windows 7
what i know is that monitors don't need drivers. if your monitor is new then i believe it is already windows 7 ready.
what you need to do is check the VGA cable if it is damaged. try replacing a new one. Hope this helps.
Jun 21, 2012 | HP 1730 LCD Monitor
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
Hello, I can not split the base for the monitor hp 1730, can assist me please, stuck in the laptop position
You have to remove four screws in order to separate the monitor base from the monitor.
Check the manual (section "Setting Up The Monitor", subsection "Removing The Monitor Base") for images of the location of the screws.
You can download the manual using this link: http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01129544/c01129544.pdf
Jun 13, 2011 | HP 1730 LCD Monitor
Pls how can i play my DVD player with my hp 1730 lcd monitor i'v tried connecting through VGA but its saying ''out of range'' what do i do? Help!
The resolution (most likely the 1080p HD) is too high for your monitor
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00477225&lang=en&cc=us&taskId=&prodSeriesId=346693&prodTypeId=382087
. You will need to access the dvd player's menu somehow and reduce the resolution to one that is supported: ideally it should be the 480p SD one that your player surely supports. The exact procedure is in the manual.
Apr 13, 2011 | HP 1730 LCD Monitor
Monitor keeps going to sleep
try it on another computer, if it still doing the same thing, probably you need to have the bak light / inverter repaired
Aug 08, 2010 | HP 1730 LCD Monitor
Hp 1730 monitor went black
if after few seconds of display and then the while display turn black, this is the indication of failed capacitor on the LCD circuit board...
you will need to have some technical skill to replace the capacitor.
Jun 21, 2010 | HP 1730 LCD Monitor
My hp 1730 lcd screen is making a humming sound which seems to get lower when i turn down its brightness but doesnt go away any suggestions?
That sounds like the inverter that powers the back-light. Unless it's really annoying I would just live with it. It's probably more expensive to repair than to buy a new similar sized screen.
Oct 08, 2009 | HP 1730 LCD Monitor
Inverter Board location---
No, that is just the connector. The inverter board is inside the LCD on an elongated printed circuit board. Its input would be pure DC as opposed to AC from the 120 mains. Its function is to produce high frequency/high voltage to supply the Cold Cathode Florescent Lamp(s) which provide the backlight illumination of the LCD panel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Computers & Internet Logo
786 people viewed this question
David Payne
David Payne
