Ft load washer
LG WM2233H, is it normal for the washer while it is washing clothes to stop and start reversing direction each time?
    Problem Solver:
  • 14 Answers
Yes this is part of the agitation cycle it aids in the removal of dirt
Posted on Apr 17, 2008
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
Need to replace drain hose on wm2233h washer
WASHER EXPERT
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 18, 2011 | LG WM2233H Front Load Stacked Washer /...
LG WM2233H stop worrking in mid cycle, no displya
This has happened to me when the power has gone out. It doesn't display anything and all you can do is restart the cycle.
Jan 17, 2010 | LG WM2487H Front Load Washer
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water is slow to come into machine, we have hard water. A Filter?
You might have sediment from your hard water built up in the water valve to the clothes washer. You might have to replace the water valve. These clothes washers do not have a filter in the for the water. Hope that helped,
XCEL Energy Repairman
Apr 28, 2009 | LG WM2233H Front Load Stacked Washer /...
Adding clothes after wash started
It is best to finalise what clothes you want to wash, regarding front loaders. Or if you stop the machine, you have to wait for a couple of minutes for the door mechanism to release the lock, before u try the door. At times the door won't open for there is water in there; & if you force the door you'll damage the door assembly. So a lot of caution here!
May 09, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
I'am new to ft loading washer & dryer. Is it normal for the washer to stop and start often while it is washing clothes?
yes it switches rotation ever so often so it has to stop to start in the oppisite direction
Apr 17, 2008 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
