How to refill the toner for Konica Minolta 1300/1350W
  • 74 Answers
Looking at the front of the printer if you look at the cartridge on the right their will be a white cover/plug, pop that off and away, you go.
Posted on Apr 17, 2008
Konica minolta 1590mf i replace toner still asking replace toner
did you refill? if so useless as there are electronic chips on them once done done!!!. Go out and buy OEM not third party toner
Jun 16, 2017 | Konica Minolta Office Equipment & Supplies
Konica Minolta 1580-MFP how to reset replace low toner message printer ?
  • Purchase OEM toner, toner has chip on it chips say toner case is empty it is empty you replacing the toner will not fix that
May 04, 2016 | Konica Minolta Office Equipment & Supplies
Toner error
There are chips on the toner cartridge, that how the printer known it got a new cartridge so refilling does not work.
Jan 05, 2014 | Konica Minolta PagePro Office Equipment &...
My konica minolta 130 f is asking me to replace toner. I have opened it, refilled but is still asking me to replace toner
what you need to do is to change the toner cartridge. Refilling will not reset the toner IC inside the cartridge so by so doing, no notable change is witnessed.
Jun 12, 2011 | Konica Minolta Bizhub 362 Copier
How to refil konica minolta toner
Shop for the appropriate refill kit. When purchasing a refill kit, double-check to be sure that the toner in the kit is compatible with the toner required for your model of Konica Minolta printer.
  • Step 2 Empty the old printer cartridge. Be sure to completely empty the printer cartridge that you plan to refill. A compressed air can is ideal for this purpose and can be purchased online or at most office supply stores.
  • Step 3 Remove the plug. The cartridge plug may be covered by a colored end plate, depending upon the model of your Konica Minolta printer. Simply unscrew the end plate, and then remove the plug. If using a screwdriver to remove the plug, be careful not to puncture the plug, as this will cause the toner to leak out of the cartridge and into your printer.
  • Step 4 Refill the printer cartridge. Shaking the powder in the refill toner bottle before attempting to pour it into the cartridge will cause it to pour much more easily. Do not squeeze the bottle, but allow the toner to simply pour out. Replug the cartridge, and gently shake or rock it back and forth two or three times to evenly distribute the toner powder inside the cartridge.
  • Step 5 Check for leaks. Before returning the cartridge to the printer, check the outside of the cartridge for any powder particles that may have spilled or leaked during the refill process. Wipe the particles off the cartridge, and gently shake it once more to check again for leaks. If no powder particles appear, then it should be safe to return the cartridge to the printer.
  • Step 6 Return the cartridge to the printer. Once you have refilled the printer cartridge and have checked for leaks, you may now return it to the printer. Go to your printer properties/settings and select the option to indicate that a new printer cartridge has been installed. Print a sample page to check print quality
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    May 22, 2010 | Konica Minolta PagePro 1350W Laser Printer
    Konica minolta 9J04 refill
    Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
    Chip reset device for Konica Minolta Bizhub and CF imaging units
    http://www.chipreset.eu
    Nov 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
    Konica magicolor 2400W
    To clear chip after refilling toner cartriage.
    Go to "Tonerfillyourself.com" I bought refill toner and it includes a new chip and it's not hard to replace it. (Comes with instructions)
    Apr 09, 2008 | Konica Minolta magicolor 2400 Laser...
    Error code
    toner chip is gone replace cartrige
    Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
    66 people viewed this question
    jasbo
    jasbo
