Question about Audiovox VD1400HT System
Won't play blue ray discs
Audiovox VD1400HT System won't play blue ray disc says it is loading
Your unit was built before there was Blue Ray discs. The DVD is not a Blue Ray DVD player
Posted on Oct 07, 2008
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
My blue ray player changes from Blue Ray player to Network when loading a Universal movie.
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 06, 2013 | Samsung BD-D5700 WiFi blueray disk player
Vbr220 will not play blue ray but will play dvd it ejects blue ray disks
Does not play disc
1.No disc. - Load a disc into the tray.
2.Disc has been loaded upside down. Place the disc with the label side up.
3.Disc region code does not match region code of the player.
4.Disc type is not the correct type to play.
5.Disc is damaged or dirty. Clean the disc or try another.
6.Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.2_9_2013_12_09_45_pm.jpg
Use the owner manual for additional information.
God bless you
Feb 09, 2013 | Vizio Televison & Video
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Apr 24, 2010 | Sharp AQUOS Blu-ray Disc Player
Head spins and say "Loading" but then says "No Disc"
I cleaned the lens, but I also tip the play upside down with the disc in it and it seems to work.
May 27, 2009 | Audiovox D1917
PS3 Wont Play Game OR Blue Ray Disc
reset to the factory default then load ver 2.60(most current). If the system still does not read any discs the laser is bad.
Dec 05, 2008 | Sony Playstation 3 (PS3) Console
Audiovox VD1400ht
I have the same model #VD1400HT.
Problem #1- the drive belt on the tray has "streached"
Solution- replace or cut out 1/4" & superglue back together.
Problem #2- the ribbon cable under the DVD assembly is hitting the bottom of the DVD tray as it attempts to open.
Solution- rebend the cable or apply tape to hold down.
These fixed my problem.
Apr 01, 2008 | Audiovox VD1400HT System
Audiovox VD1400HT System Logo
169 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
