Question about Euro-Pro 9000 Mechanical Sewing Machine
Euro Pro 9000
My sewing machine has been sitting for a very long time so I decided it was about time I oiled it. The operator's manual indicates only one location for oil; inside the bobbin mechanism. Is this correct?
  • mowingangel Apr 17, 2008
    Thank you for your advice! I appreciate it. However, is this only location on the sewing machine that requires oil?
    Thanks!
    My Singer was that way, but these instructions are so primitive! There is only one comment referring to lubrication and that indicates the bobbin area.
    I'll get at it!
bargainbox
  • 1388 Answers
SOURCE: Euro-Pro 7133 - Thread is getting stuck underneath
Make sure you clean up all the oil......it is not a universal cure all contrary to opinion....
Now, down to business..........
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 25, 2008
I had the exact same problem!!!!finally i took to the store and they showed me that i was not threading the too string correctly. what you have to make sure that the needle is at its highest position and that you thread it through all the guides!
Posted on Mar 07, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
SOURCE: help me find a manual for a euro pro 7133 sewing machine
Contact Shark @ 18003614639 they will send you a manual. They were very helpful and courteous.
may we all find some peace in thse manuals.
Posted on Nov 17, 2008
Michaelle
  • 65 Answers
SOURCE: friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
Posted on Jan 24, 2009
The belt needs to be replaced on euro-pro sewing machine. How do I get it off?
it is possible that it could be the belt, but it's also possible that it could be the power cord or foot pedal,, only a sewing machine repair shop can tell which it is
Jan 18, 2012 | Euro-Pro 9000 Mechanical Sewing Machine
Where to oil my euro pro x 473B
Check your owners manual. Most machines like Brother, Euro-Pro and a few other budget machines recommend that you DO NOT oil them.
The reason is that most of us want to "grease it up real good" but oil when left to set can become varnish like and seize up your machine.
If you think it's time for oil, it's best that you take it to a qualified sewing machine technician and have him clean, oil and adjust it for you. While you are there, ask where to oil for future reference if it's recommended at all.
Mar 12, 2011 | Euro-Pro 473
I need replacement sewing extension table that came with my machine
Call Euro-Pro at 1-800-798-7395 and you can order it, right from them. Good luck
Sep 16, 2010 | Euro-Pro 9000 Mechanical Sewing Machine
Need to find a power cord for a Euro Pro sewing machine, model #9000
Go to sewingpartsonline.com and you will find it there. Good luck
Sep 10, 2010 | Euro-Pro 9000 Mechanical Sewing Machine
Lost manual to euro pro multi stitch 9000 machine. where can I get one
Lost manual for
How can I get one
Jun 24, 2010 | Euro-Pro Sewing Machines
Lost manual to euro multi stitch 9000
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=3365&option=com_virtuemart&Itemid=54
Jun 24, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Machine won't sew at all
RE: Euro-Pro 9000 Mechanical Sewing Machine "Won't Sew"
I am wondering if you tried unplugging it for at least 1 minute to let it reset the onboard computer (sometimes they need to be unplugged overnight).
Try the following links....
FAQ @ http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
Manual @ http://www.euro-pro.com/europro/manuals/9000.pdf
Customer Service @ http://www.euro-pro.com/europro/feedback.aspx
Let me know if I can assist further!
jackiaria
Feb 28, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Friends broke needle on my euro pro multi stitch sewing machine.
Jan 24, 2009 | Euro-Pro 9120 Computerized Sewing Machine
How do I oil my machine
You can download the manual from the website below: http://www.euro-pro.com/europro/manuals/7500XH.pdf They also have a FAQ: http://www.euro-pro.com/europro/faqdetail.aspx?modelno=7500XH Lubricating:
Jul 31, 2007 | Euro-Pro 7500XH Mechanical Sewing Machine
Euro-Pro 9000 Mechanical Sewing Machine Logo
48 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
