Question about Hampton Bay 24002 Ceiling Fan
Wiring problems we have a hampton bay fan w/ light kit. I wired the blue & black from ceiling fan to black house wire and white ceiling fan wire to white house wire and the fan or light will work. However, I put the blue ceiling fan wire to the white wiring and only the fan works, not the light. When I initially wired the fan the lights were dim, but only came on for a brief time and have not been able to get them to come back on since.
  • renecares158 Apr 11, 2009
    hi while i was repairing the pull chain the plastic casing fell off and now i don't know which wires to connect there are four wires the black ( attached to the ceiling fan) the purple, yellow , and orange are free. I spoke to an electrian and he was unsure. if you can help i can't afford to blow a fuse.
  • brianalesi Apr 19, 2009
    I have a Hampton Bay #504149.
    I lost the instructions.
    I have a black wire and a white wire from the ceiling.
    I know to hook up the white to white and the black to black ... but what do I do w/ the blue fan wire? I assume I need to merge it w/ the black house wire ... am I correct?
  • 20 Answers
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Posted on Jun 17, 2008
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Sep 10, 2010 | Hampton Bay 24002 Ceiling Fan
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I have a hampton fan 5 blades, is the proper way to connect for the lights to is to connect the blue wire to the white wire or the black wire
If you nare adding a light kit to the base of a ceiling fan, you will connect the blue and black wires together ,, and then the two white wires ..
May 04, 2010 | Hampton Bay 24002 Ceiling Fan
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
My light kit wire is not connected
Blue, is usually international color for the NEUTRAL wire. EUROPE BROWN==PHASE BLUE===NEUTRAL Green/Yellow stripe==EARTH. (Most important wire)
USA. BLACK==PHASE WHITE==NEUTRAL GREEN/BARE==EARTH (Most important wire)
Mar 28, 2010 | Hampton Bay 24002 Ceiling Fan
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Jan 17, 2009 | Hampton Bay 24002 Ceiling Fan
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
332 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
