Question about Apple iPod nano
Raising the volume and manuvering the "click wheel to "settings
THANKS FOR THE QUICK POSTS. I LEFT THE NANO AS IT WAS "NOT CONNECTED WITH THE LIGHT ON STILL JAMMED. WITH THE BATTERY RUNNING DOWN IT SEEMED TO RESTORE ITSELF TO THE POINT WHERE THE "APPLE" RE-APPEARED. MY ONLY REMAINING PROBLEMS IS USING THE "CLICK WHEELS TO GET TO "SETTINGS" AND LEARNING HOW TO RAISE THE VOLUME!......ALL ADVICE WILL BE GREATLY APPRECIATED
  • swalerroe7 Apr 17, 2008
    Hello Ekse: Thank you so much for the ipod links. It only took me a week to finally begin to use this thing correctly !
  • Apple Master
  • 13,433 Answers
Here are some good video tutorials on how to use your ipod
http://www.apple.com/support/ipod/tutorials/
and here you can get the ipod manual to get more instructions on other settings and things
http://www.apple.com/support/manuals/ipod/
If you need more assistance let me know, I'm here to help
Posted on Apr 17, 2008
  • Ekse Apr 17, 2008
    good to hear, dont forget to rate the solution as fixya if your problem was solved Thanks alot :-)
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
How do I change the volume on my IPOD Nano. Its too loud and hurts my ears.
  • Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
  • Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
    hope this help. :)
    Nov 04, 2011 | Audio Players & Recorders
    I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
    The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
    On the home screen, tap settings
    Tap Music, then tap Volume Limit
    The volume limit control will then come up to raise the limit move the slider all the way to the right.
    If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
    Hope this helps.
    Sep 07, 2011 | Apple iPod nano 3rd Generation
    How to remove volume limit on eu ipod nano 5g
    You can set the maximum volume limit by going to settings then playback and then volume limit. This will show you the current volume limit, use the click wheel to select the maximum volume limit and then press the centre button to set the limit. Hope this helps.
    Sep 27, 2010 | Apple iPod nano 5th Generation
    Wish to remove eu volume limit on ipod nano 5th generation
    Go to settings then playback and then volume limit. You can then use the click wheel to select the volume limit once you have the volume you want use the centre button to set, Hope this helps.
    Apr 06, 2010 | Apple iPod nano 5th Generation
    When I click the left button, my v450 nano clicks the right, and when I click the right button, it didnt anything. I use Windows 7. I tested it with Vista and XP, and many computers, and I replaced the...
    hello, it sounds like your click buttons are inverted in settings, Try this: go to control panel, double click the mouse icon, select the "Buttons" tab, check settings. These settings are usually in this order:
    Left button = Click (default)
    Right button = Right-Click (default)
    Wheel Button = Instant Viewer (default)
    etc...
    make sure your right click and left click settings are correct there if not you can change them by click on the dropp down and selecting appropriate setting you prefer. You will also see a option of "Restore Default" a quick way to reset to default settings.
    I hope this helps, good luck.
    Regards,
    amar Sondhi
    Dec 15, 2009 | Logitech V450 Nano Cordless Laser Mouse
    Ipod Nano can't unlock volume lock
    Sounds like you need a New ON/Off switch which is connected to the headPhone Jack. We can definetly do this for you. Please give us a call to set up a Repair at 661-619-5928 or Email us at sales@ipodrepairz.com
    We look foward to your Business and also repairing your iPOD
    Thanks Again
    ipodrepairz
    Also check us out on Ebay.com under ipodrepairz
    Sep 19, 2008 | Apple iPod nano 2nd Generation MP3 Player
    Apple Ipod Nano 3rd Gen Volume troubles
    Seems like a manufacturers fault on your click wheel. The new nano's have their click wheels held in place with just a strong adhesive so this one might be slightly out of place.Take it straight back as faulty. Make sure inside your headphone socket isn't red else Apple will say it's water damaged.
    Aug 17, 2008 | Apple iPod nano 3rd Generation
    First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
    You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
    If that doesn't work, try a restore. This will return it go factory settings.
    How to restore iPod
    1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
    2. Download and install the latest version of iTunes if you do not already have it installed.
    3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
    4. After a few moments, your iPod will appear in the Source panel in iTunes.
    5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
    6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
      • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
      • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
      • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
      • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
    7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
    8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
      • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
      • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
    9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
    10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
    Jan 01, 2008 | Apple iPod nano
    Apple iPod nano Logo
    61 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
