Question about GPS
Gogo plus navigator
Is it possible to put other software on this unit because the original software is to confusing to use and doesnt always pick the best route, i believe its running some form of windows software sticker on the back says "Win CE .NET 4.2 Core"
the only way to update the maps etc is thru adding to the SD card, but surely this could be connected to a PC, there is a TMC? for something to connect into, any idea's?
Gogo cm310 software updates
Posted on Feb 06, 2009
My car radio has problem with sd Navigation Software
If you have issues with the navigation software in your unit you can always go to the web site and check for firmware/software upgrades that are designed to make your unit work better and faster with the internally loaded maps.
If your maps are not up to date then you can always request and get a map software update but that will cost you about 50 bucks.
Sep 11, 2015 | GPS
Why wouldn't my ifinder h2o c gps not pick up any satalite signal
The most common reasons are thus
1) You do not have the right PORT and BAUD set
Consult the manual for the software.
2) You are noit in a location where the sky is visible to the unit)
move outside and away from buildings or electrical items
3) Your battery power is too low to get a fix
4) nThe SIIRF chip is damaged
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Lowrance iFINDER H2O C Plus GPS Receiver
Problem with PCM Navigation
Hi I have a 2006 Caymans S and have exactly the same problem, everything works except the Sat Nav!
In the navigation option menu, it lists 0 satellites being picked up
The dealer looked at it today and replaced the GPS antenna, but didnt fix it. They too mentioned about a new unit...
I will post if I solve it, but if you find out what is wrong I would really like to hear about it.
Dec 15, 2009 | 2003 Porsche 911 Carrera
I HAVE A VISCO 530A GPS. WHEN I CLICK ON MY GPS , THE SCREEN SAYS "CANNOT FIND NAVIGATOR.EXE'. CAN YOU HELP?
you have to put the sd card that came with the unit into the unit. the card has the navi software on it.
Jul 09, 2009 | Intervideo WinDVD 4 Plus (WDVBF-7663-40RC)
Evespan is frozen up at the start,whAT can I do
You need to test the SD card to make sure it's reading OK. Next step if it is OK, reformat the card and copy the files from the original cd that came with the unit, on to the SD card and that should fix the problem. If the SD card is defective, just get a new 1 or 2 gig SD card and copy the files on that card. It's ALWAYS helpful to have an extra SD card as a backup. If you don't have the original cd, I have the original as well as the new N30 version software for the Nav-Cam 2007. Joe
Nov 30, 2008 | Navigator Evesham Nav-Cam 7000 GPS...
RB4 Calibration / Sensors Menu Question
Hi Chris
I have run across the problem with the display showing that you are going backwards on units I work on my bench.As long as you are getting the distance pulses and the nav functions are operating properly the should be no problems.You reinstall the 2060 ver and see if it reverts back to the way it was.Then reinstall the 2070 ver again.The main changes that were madewere to the update speed for the GPS functions.I do have a service manual,but cannot release it to anyone.From what i understand I am the only one that is Factory authorized to repair the RB4 units in the USA.
Feel free to msg me about any other questions you have about the unit
Yes theCAN BUS could cause a problem.
The 07 chrysler's use the highspeed CAN C in some of the app's in the vehicle.But from what I understand they are only using 125hz can BUS speed(which some consider low speed CAN) But as you mentioned the radio is talking on the BUS so it must also have J1850 communication.The RB4 does not have CAN built into the unit.
Jul 07, 2008 | 2007 Jeep Liberty Sport
Eclipse AVN-5435
for avn 5435 on the left:press menu and cont ant the same time, while holding them down press menu on the right 5 times
a menu will appear and ask you for a code. you have to call 800-233-2216 and pay $25 for the code. you will have to explain where you bought your eclipse and or know the name of the original owner. if it doesnt match they will not give it to you
Dec 07, 2007 | Eclipse AVN5500 Car DVD Player
GPS Logo
214 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
