Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
GWL15 will not operate
Display lights up as if every thing is fine. I push start and machine just beeps
    Problem Solver:
  • 6 Answers
If it's a beep every second, call Fisher & Paykel 24/7 call center and tell them what lights are lit up on the wash progress lights and they'll be able to advise you what the problem may be. You'll likely need service though. If the beeps are musical - you're user guide should give you some options on what to do - otherwise call F&P and they'll help
Posted on Sep 22, 2008
GWL15 fisher and paykel stops mid spin
If the only light on was the spin when it was beeping,
That is fault code 1
1. (00000001) Motor Control Module Fault
The Motor Control Module has encountered an error when writing to an EEPROM address.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 18, 2013 | Fisher Paykel EcoSmart GWL15
The machine stops on spin cycle and beeps when it is empty.
Hi just read your posting.Now when the machine is beeping an error code will be displayed.If your machine has an LCD display it will appear in it.If your machine has no LCD display then a series of lights will light up when the machine is beeping.These lights that are lit when the machine is beeping will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping, is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 15, 2010 | Fisher Paykel EcoSmart GWL15
Won't rinse and spin
Hi just read your posting.Now does the machine drain the water after the wash part of the cycle?Does the machine beep and show an error code,if so which lights are on while the machine is beeping or what error code appears in your LCD display if you have this model?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 10, 2010 | Fisher Paykel EcoSmart GWL15
An alarm sounds when it gets to the rinse cycle and it will not proceed any farther. Jeff
Hi Jeff just read your posting.When the beeping starts a series of lights will start to flash .These lights will be in a row of 8 lights.Starting from the left to right which ones are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc---?If you have the model with an LCD display then the error code will show as it beeps.Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Jul 28, 2010 | Fisher Paykel EcoSmart GWL15
Get half way thru and stops
Hi just read your posting.Now when the machine stops does it beep and show an error code?The error code will be shown in the LCD display if you have that model or by a series of lights that come on while it is beeping.If you have the model with the lights then on that row of lights ,"there will be 8 in the row" starting from left to right what lights have turned on while it is beeping?Are they the 3rd and 6th or 2nd and 7th --etc--?Please reply with additional information about the error code and I can guide you throe this problem.
Jun 22, 2010 | Fisher Paykel EcoSmart GWL15
GWL15 starts to fill, water shuts off & water coming in slows to a trickle. Hot & Cold lights flash, machine beeps. If filled with buckets of water cycle will finish.
A common fault with F&P machines is in the water inlet valves.It is not afvisable to exchange the hot and cold valves because they are different. The faulty valve should be replaced. . Goodluck.....Nomess
Apr 23, 2010 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel EcoSmart GWL15 Machine won't agitate or spin - two yellow lights come on, and machine beeps every second or so. This happens even with the power off.
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 12, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
153 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
