Question about Frigidaire GLWS1233A Top Load Washer
When cyle is finish clothes are still soaking wet
There is about 2 to 3 inches of water left in the tub if doing cycle without clothes. Not making any noises checked hose it was bent fixed that still having water in tub as well as clothes still soaking wet have to repeat final spin.
  • 2 more comments
  • Anonymous Apr 22, 2008
    I have a top loading washing machine (frigidaire). The problem is there's a little water left after spinning.
  • mcox193 Jul 12, 2008
    SAME HERE.. WE HAVE CHECKED THE DRAIN HOSES AND THEY ARE CLEAR.
  • mcox193 May 11, 2010
    how can i tell if the impellor is broken?
  • Anonymous Mar 13, 2014
    clothes are soaking wet
  • 145 Answers
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Posted on Apr 17, 2008
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 01, 2010 | GE WSXH208A Front Load Washer
I am very unhappy with this machine and sorry I bought it! It uses so little water that sometimes when I take the clothes out after it is finished washing I can see dry spots on the clothes that never even...
How about putting the clothes in and pouring water over them with a jug before the washer starts its program ?.
It could also be that the water level switch is out of tolerance and needs replacing
Most machines have a pre-wash cycle as well
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Clothes are sill soaking wet after sin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Aug 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Apr 01, 2009 | Bosch Washing Machines
Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Frigidaire GLWS1233A Top Load Washer Logo
459 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
