Question about Sony FD Trinitron WEGA KV-32FV300 32" TV
32 wega trinitron
My picture tube is getting weak, from your post and by the way thanks for that post. Question, I fall asleep to the tv. Does this shorten the life of the tube versus turning a tv on and off. Our tv is about 12 years old and is this an average life span of a tv in todays world. thanks in advance for your help and its valuable to have someone such as yourself helping others troubleshooting problems so thanks!
    Sergeant:
  • 359 Answers
Surprised it went 12 most 8-9 not Worth the fix
Posted on Feb 06, 2009
The screen will show a white line every few seconds, then will black out, this will go on as long as the TV is plugged in.
The Picture Tube of the TV must have got damaged. Give the TV to TV brand's technical support and change the picture tube, Thank You.
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My triniton wega tv 32 inch flashes 5 times and i lose the picture then it comes back on lasts awhile then lose the picture again flashes 5 times again over and over
you can ensure the connection and Heater's voltage, start from Flyback transformer ( Heater Pin) to Heater of the CRT tube, whether exist and normal ( Include : check Resistor in Heater area), perhaps there is lost connection for a while and connect gain. There should be 5 Volt AC available. otherwise check the socket of CRT Tube, unplug and clean it. If there is any question you can ask me and clarification with detail result from my solution.
Aug 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color is off and picture is bad
these tv's are common to have weak picture tubes. a crt rejuvination machine should restore normal operation for a few years
Dec 27, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen goes black every few seconds but have a picture
Sony incorporates a video blanking circuit that blanks the picture out when the picture tube begins to get weak. sorry, but short of replacing the tube, there's no lasting solution to this problem. I used to have some success rejuvenating the crt, but I found that it didn't last but a few hours before the blanking circuit starts to activate again.
Apr 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wont turn on.
your picture tube is weak.
not economical to repair.
it is cheaper to replace it.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby
I think your picture tube is weak.
You can verify this by taking the back off and slowly adjust the the screen control (it is mounted on the flyback transformer) the one with the wire coming out the top and going to the picture tube
the lower one. it is black and serrated and less than 1/4" in diameter.
turn counter clockwise first then advance it while someone watches for the picture.
If it comes on you know the tube is weak.
it may last for a while at that setting, but be prepared to buy a new set.
Thanks Guy9
Jun 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
On picture
Hiii...
Try to check the M board,IC001,G2 ( Screen ) Voltage....
Thank's
[vrya]
Mar 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking stand by light
the cause of your problem is in the crt socket your tube may be weak.try to adjust the g2
Jun 19, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FV300 32" TV Logo
141 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
