Question about Dell Dimension 4600 PC Desktop
Sound There is not any sound coming from my speakers. My granddaughter went on Toon Town web site and we could hear music. But all other sounds cannot be heard. I can hear the speaker when I turn it on and off. I have checked all plugs. I have gone to properties and all of my sound is on. Nothing is on mute. Where else can I check?
  • 3 Answers
Install motherboard software den restart your pc, tnx
Posted on Apr 17, 2008
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
Rear speakers have no sound
No speakers are not fused.. It is most likely a speaker wire that has gone to ground so they would have to be traced to each speaker to see if you can find the short
Jan 10, 2014 | 2007 Toyota Camry
The sound is gone. I cannot hear anything when somebody calls me. However, the alarm sounds and all the rings. I can hear my music but only with earphones.
The loudspeaker is what the ringer uses as does the music, the inner speaker is used for hearing calls. Sounds like your inner speaker is faulty, check with where you bought it and it may be free to repair if its still under warranty (usually 12 months from date of purchase)
Sep 05, 2011 | Nokia E5 Cell Phone
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
We have the leapfrog learn & groove activity table. The sounds coming from the table are intermittent which makes me think it may be a loose connection. How can I check this? I have changed the...
Based upon your brief description, it sounds like the internal speaker itself has worn out (likely cause) or possibly the internal speaker wire(s) are becoming disconnected or may be shorting out.
LeapFrog has discontinued product support of our "Learn & Groove" Musical Table with green legs that was made in 2010. LeapFrog Customer Service declined to discuss replacement parts, so I searched eBay for an exact speaker replacement.
BTW, I am not affiliated in any way with the eBay seller nor do I work for LeapFrog... I'm a Computer Engineer/Geek in Cincinnati, Oh trying to solve a simple toy problem. All opinions expressed are solely my own and do NOT represent any technical guidance from the original equipment manufacturer. I am only trying to fix my Granddaughter's toy that abruptly stopped working!
Correct replacement speakers are available on eBay and ship from Hong Kong... I just bought qty2 of these speakers for $5.69 total inc s/h/p (only 1 was needed). Delivery time was slow, but well worth the wait...
When the replacement speakers arrived, I had to take off the back panel screws and unsolder the original speaker, so I could resolder in the single replacement speaker under the 2" black cover. The "Learn & Groove" Musical Table speaker now works great!
Some forum posts say that resoldering a computer modem speaker (16ohm .25w) could be used, but this is a temporary solution at best. The replacement speaker from Hong Kong produces a better quality sound and more sound volume when used with the "Learn & Groove" Musical Table.
The speaker replacement specs for the LeapFrog "Learn & Groove" Musical Table with Green Legs are as follows:
"Round Aluminum Shell Magnetic Type Slim Speaker Horn"
.25 watt
Resistance 16 Ohm
Type Internal Magnetic, Slim
Shape Round
Bottom Diameter 20mm/ 0.8"
Outer Diameter 35mm/ 1.4"
Height 9mm/ 0.35"
Material Aluminum, Metal, Plastic
This replacement speaker worked great for me and now my Granddaughter can again enjoy her toy that I was able to fix!
Dec 13, 2010 | LeapFrog Learn and Groove Musical Table
The background music is louder than the voices
in the menu there should be some type of set up for this, it will most times show you on your screen a room with all the speakers in it and ask you to hit test then it will shoot a white noise type of sound around to each speaker and ask if you heard it, there are then adjustments you can make for the front, rear, and side sperkers independent of one another.
Mar 23, 2009 | LG LHT854 Theater System
Cant hear nothing!!!
Yes the problem is coming from the speakers , so take the phone to a repair center and have them replace the speakers for you.
Jul 09, 2008 | Sony Ericsson W850i Cellular Phone
Can't hear voice of singer on speakers, more of an echo sound
Hello Shemon
Well, there is 2 option here, 1) your sound speakers are not connected corretly or in the right slots on the sound card.
2) your sound card, (internal or external) you have to use the mixer on software to put the right channels for the music you heard. try configuring in control panel, in multimedia devices, the speakers. for 5.1 system, or 2 way speakers or 3
try again
Dec 25, 2007 | Bose Companion 3 Computer Speakers
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
Feb 09, 2007 | Eltax DV-100 DVD Player
Dell Dimension 4600 PC Desktop Logo
60 people viewed this question
Alun Cox
