Question about LG 32LX1 32 in. HD-Ready LCD Television
No video, not even menu
The tv is on, but there is nothing on the screen. Not even the menu option, input change, nothing. The tv is one week old and worked fine until now, yet nothing has changed. I think I have lost faith in LG.
  • nancycr May 03, 2008
    TV is on - green light is showing. No picture, no sound. TV is 2 months old.
  • jnericson Jul 04, 2008
    YES!!! Same problem!! The TV just went off!! and won't come back on! The "red glowing" light is on but no picture, no sound, no menu!!! Why did everyone tell me that LG was so great??? It is 1 MONTH OLD!!! Are you KIDDING ME??????
  • 85 Answers
Replace power supply
Posted on Sep 04, 2008
    Sergeant:
  • 395 Answers
If the tv is only a week old take it back to the store where you bought it for exchange or call LG for service under warranty. these units ( all LCD, Plasma and DLPs are essentualy a computer and have glitches). during mass manufacturing of these sets no matter the manufacturer problems will arise because of enviromental laws that prohibit the use of leaded solder. no lead solder takes higher heat to melt and different acids are used to clean the contacts. this posses problems to all manufacturing. the sets of yesteryear which lasted longer because of larger components and better soldering have gone by the wayside. don't lose faith in the manufacturer wave the figer at the enviromentalist that caused the problem.
Posted on Apr 17, 2008
I keep getting a blue screen on my Insignia TV. Cable box still shows the channel and I can change channels but nothing on screen. No sound either. This TV is not even 3 years old yet.
A blue screen indicates no video signal, if you change the video input to a DVD player is it still a blue screen? If yes then the TV is defective. If no then some how the signal is being lost to the TV from whatever source you use for watching broadcast TV
Apr 05, 2017 | Televison & Video
My Sanyo tv stuck in Please Select Language screen. I have unplugged tv, changed batteries in remote. I'm also am stuck. Tv is a year old. No power outages either.
Depending on the unit you have if you have more than one input (mine has four HDMI, Computer, Standard TV, etc) you may need to be on the right channel or input. You should be able to bring up an On Screen Display that will let you make changes, You might want to try the Menu key on the remote to bring this up. If nothing else go to http://sanyo-av.com/support/ and find your TV and look at the manual.
Jan 26, 2017 | Sanyo Televison & Video
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around...
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
DO YOU WANT THIS INFORMATION?
A VERY HELPFUL RATING IN RESPONSE TO THIS SOLUTION WILL TELL YOU HOW TO GET INTO THE OPTION MENU.
SD TECH (in San Diego)
Aug 22, 2010 | Mitsubishi WS-55613 55" Rear Projection...
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Impossible to get video input to show
It is possible that the physical connection inside the set is broken. Can you solder? If so, update this and I'll provide more information and instructions.
Dan
Sep 25, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
DVD's will no longer play in color
We had the identical problem, which was solved by changing the input channel on our Panasonic plasma screen. This was not obvious and we needed help from the person who installed the system. The input channel had changed automatically!
Feb 07, 2007 | Sony DAV-S300 System
LG 32LX1 32 in. HD-Ready LCD Television Logo
70 people viewed this question
Computer Repairing
Computer Repairing
