Question about Microwave Ovens
My microwave oven does not power on. what can be the problem, it is a year and 6 months old.
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven. If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
Turntable
The turntable motor is defective, since it is 6 months old your warranty should cover the repair or replacement of the microwave oven.
Apr 04, 2012 | Magic Chef Microwave Ovens
We can put in the minutes and temp., then when we close the door the clock times down and the fan blows, but nothing cooks. Fridgidaire model cfmv156fmc. For a while if we put a piece of cardboard in by...
I threw mine away because frigidaire would not do anything for it and was less than 6 months old . local dealer would not look at it as we bought from a big box store not them .
Dec 09, 2017 | Frigidaire Microwave Microwave Oven
Microwave is 6 monthes old. will run table will turn but not heating properly hearing strange sound and smell.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 27, 2010 | Frigidaire PLMV169DC Microwave Oven
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
GE JNM1851DM. only 6 months old and it is dead. Worked fine and then all of a sudden stopped working. The wall outlet has power so I know it is not a breaker in the house. Nothing works on the micro. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | GE Microwave Ovens
Same problem - The handle broke off when opening. Microwave less than 6 months old. Cheap plastic handle and cheap plastic clips hold it together.
Since it's less than six months old, it will be under warranty.
You can contact the manufacturer for free repair.
Just look up their contact information in your owner's manual.
Dec 06, 2009 | Samsung SMH7178STD Microwave Oven
I was making popcorn and the microwave just died
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jun 07, 2009 | Magic Chef CMV1000B Microwave Oven
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
My microwave turns on but does not heat up it is only 6 months old wot can it be
It may have a defective magnetron. If this microwave is 6 months only, still under manufacturers warranty and you should take it for repair.
The magnetron has a warranty of 5 years in some cases, read the warranty section of the users manual.
Good Luck.
Feb 11, 2008 | Microwave Ovens
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
