Question about HP LaserJet 2550L Printer
All Lights are flashing
All the lights are flashing when i go to print it doesnt even come up with an error msg and that drums arent rotating and i know its not the ink or a paper jam! Help!
Well, i presume there's a grounded circuit on your printer's system. Don't let things get worst coz things might go expensive on repairing your printer. have it check at HP certified personnel. i cannot help you with your querry since i am no position to see personally the condition of you printer.
Posted on Apr 17, 2008
Error code H101 and also P18531. Lights are flashing. Will not go.
Error H01: Ink color setting error Cannot get consumables info inut values required. Enter the required parameter value. (1: black / 2: color)
Error P18-531: Type P18: Drum-lock-solenoid lock. Point 531: Print dum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated. Hints: Check mentioned sensor. Check mentioned solenoid.
Sep 13, 2010 | Riso RZ390 Duplicator
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
I have a brother printer 2140 and the drum light stays on :0
You have to open the door and hold the go button til all lights flash. That tells the printer it has a new drum. After that press the go button 3 times and it will print a report that shows the drum as new...
Jul 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Won't Print But Ready Light On Fan nonstop
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Apr 04, 2008 | Brother HL-2040 Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Error msg
Hi Usually with this printer, you just simply turn it off and then on again and the lights will stop flashing. This is an LSU (Laser Scanner Unit) error. If you still have the problem, it might be either the LSU needs replacing or it could be the main board. These parts might be scarce though and very expensive. It might almost be cheaper to buy new printer but that is up to you to check and decide for yourself.
May 24, 2007 | Samsung ML 1210 Laser Printer
HP LaserJet 2550L Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
