I am trying to disble the security encription for my Motorol router but I have lost the user id and password info to open the gateway
    Sergeant:
  • 202 Answers
Hello boboso1
If you do not have the login to access the router's UI (user interface), then you must physically reset the router to factory default settings in order to regain access to the UI and to disable its wireless encryption. (Wireless encryption is not normally enabled w/ the default settings.)
If you would like to give us the router manufacturer, model number and version number, we can point you to where you can find the owner's manual for this router.
The manual will provide you w/ directions for reconfiguring your router.
If you have any more questions, just ask. We're here to help.
Thank you,
BJ @:)
Posted on Apr 17, 2008
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello boboso1
    How did it go? Were you able to reset your router and gain access its user interface again?
    Hopefully that is the case. :)
    If it is, would you kindly take just a moment, please, to rate my solutions w/ a FIXYA? I would really be grateful.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
How do i lock my internet connection so others can't use my connection
Hi onlyforu48,
I see that you want to put Security on your Network Connection.
1. First we need to find out what Default Gateway your Router has, this depends on what Router you have. To find your Default Gateway we need to click on Start then click All Programs, Accessories, Command Prompt, this will show you a black window with a blinking cursor.
2. In Command Prompt type in IPCONFIG then press enter, this should should pull up information showing your IP Address/Subnet Mask/Default Gateway, we need the Default Gateway info only it should look like an IP Address ex. 192.168.2.1
3. Once we have your Routers Default Gateway we will need to open Internet Explorer or any browser that you my have on your computer, type in the Default Gateway on the Address bar then press ENTER, this should prompt you for a user name and password. If you have changed your Routers user name and password please use the User Name and Password that you have created if you haven't changed any thing on your Routers user name and password then you can try admin for the User Name and password for the password or admin and sometimes you can just leave it blank.
4. Once inside the Routers settings page look for wireless then under wireless look for security this should give you the option to create a Network Key in your router, make sure your write down your network key on a piece of paper incase you may forget.
I Hope this will help regarding your Router security question, have a nice day.
Apr 03, 2011 | Computers & Internet
Motorola wr850g. I forgot my password for my router, I've tried to reset, and when I access router from hardwired computer of course it asks me for user ID and password. Please help!
Open your Internet Explorer browser:
In the URL field, enter
http://192.168.10.1 (the router's default IP address) and press the Enter key.
Enter as follows:
User ID: admin
Password: motorola
Once you have logged in, for security reasons you should change the User ID and Password.
Oct 07, 2010 | Arris WR850G Router (DHWR850G)
How do i alter my security settings on my router
You need to login into the Router's control panel to be able to change the settings. For the link, this is usually the gateway address of your computer. If you are using windows, click Start, on the RUN dialog box, type cmd. It will open a new window and you need to type this:
ipconfig
Note the Gateway info. Open up a new browser window and then input the gateway address. Ex.
http://192.168.0.1
If it asks for a username password and this has been never set, you can use the default combinations. Try to type admin and leave blank for the password field. Try admin and admin for both the username and password. You may refer to the user manual for the default password as well.
Once logged in, you can browse the interface and then check for the security settings.
Jan 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Trying to locate my wep code for linksys
Sir, you are the one who's going to make the wep code or password. To view this, go to the configuration screen of your router then wireless tab and under it click wireless security.
Oct 01, 2009 | Linksys Wireless-G WRT54G Router
My wireless connection is unsecured I'm using a Netgear router,what do I do to secure my line?
1. Goto your web browser
2. Type 192.168.0.1 or 192.168.1.1 (depending on which Netgear router, just try both).
3. Type "admin" for username and "admin" for password.
4. Click on "Wireless settings" on the left frame of the router setup page.
5. Security options are on the main frame of the page now (under security options). Click on WEP and enter a WEP ID (make it unique).
6. Click on "Apply" and repair your wireless connection. It should prompt you for a WEP key.
Hope this helps,
Bill
Sep 05, 2009 | NetGear WGR614 Wireless Router
I have lost the security password/key to set up wireless router
if you don`t have anything like wep or wpa on the back then you have to get into your router settings. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway open Internet explorer and type default gateway in the address bar.hit enter type the username and password for the router.goto wireless settings and you can check the security if not then you can make one.take care.
Jul 01, 2009 | D-Link Wireless
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
I need to encript my router to prevent other users from using the signal
When the router was installed I did not encript it with a password to prevent other people from using the signal. I woul'd like to set this security. Also I woul'd like it to stop broadcasting.
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
